The new battery doesn't charge
SOURCE: e-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
SOURCE: My sons razor e200 dies quickly. I have changed
Problem is not the batteries then. Replace the controller. The controller could be resisting some of the charging current to the battery.
But first try this:
Charger the scooter with it OFF
Directly connect the charger to the battery
If still the same problem then:
Directly connect the charger to the battery then,
connect the motor leads directly to the battery and see how long it runs. It with new the batteries it should run longer than a minute. If it does than something is definitively wrong with the controller.
SOURCE: Bought a new battery for
take a look at the other one and see on which side the wire was hooked..on +or - or both where ...and just get some wires if they need to be longer ..and hook it in the same screw with the normal power line ..but remember from the other one ..which and where ..
