some one sent me a fax, is there a way to reprint it from the memory?
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
The
fax element of the Printer contains a memory feature for storing
faxes in the event of a printing problem. This feature is useful for
protecting yourself against missing faxes if your printer runs out of
paper. In order to retrieve missed faxes, the feature must be
switched on when the faxes arrive. You can reprint faxes stored in
the device's memory from the main control panel. You should allow
approximately 5 minutes for this task, or longer if many faxes are
stored in the memory.
Instructions:
Load paper in the input
tray.
Press
the "Setup" button on the front of the printer.
Select
"Tools," then "Reprint Faxes From Memory."
Press
"Cancel" to stop printing. Faxes are printed in reverse
order; the most recent fax is the last to print.
10X
