Insulation Logo
Paul Posted on Feb 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How does window insulation film work? - Insulation
charlie
Level 2:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 67 Answers
  • Posted on Feb 05, 2014
charlie
Expert
Level 2:
New Friend:
Teacher:
Answers
67
Questions
46
Helped
45293
Points
214
Solar control film (if that's what you are asking about) helps reduce heat transfer through windows. The film absorbs the UV elemnt of the sun's energy while reflecting the infra-red elements.
  • charlie Feb 05, 2014
    It also helps to control the amount of sunlight you get in the summer.
How do you cover a glass window for privacy?
There are many ways. You can install blinds, curtains, shutters, and drapesto protect your privacy. They could also block out excess sunlight and noise, provide insulation, and add a touch of elegance at the same time.
The problem with these types of window treatments is that they have to be cleaned/washed. You also have to manually open and close them as your needs for privacy and brightness alternate.
A good alternative to traditional window treatments is switchable glass. As the name suggests, switchable glass allows you to control the level of light that comes through your windows. One moment the glass looks transparent, giving you a clear view of the outside world, and then the next, it's opaque, giving you complete privacy and sun protection. Fortunately, you don't need to redo your entire window installation to enjoy the benefits of smart glasses. You can easily purchase and apply smart films from Smart Tint to transform your existing window into a switchable glass.
The buttons on my tredmill only work when they want too why.. its a trainer 480 from gold gym
Chances are the oil and sweat from your fingers have gotten under the buttons, the oil film insulates the contacts and they stop working. or work intermittently. Open it up, clean all the contacts on the circuit board (q-tip & rubbing alcohol), as swell as the bottom of each button, then reassemble.
4helpful
Pacific Image PrimeFilm 1800u Film Scanner : is there a Windows 8 driver out there somewhere? Can anyone offer some help in finding it?
PrimeFilm 1800u will not work on Windows 8.
Here is the response I received from the company for the question:
Where can I get drivers for windows 8? Windows 7 drivers are not working on Windows 8.
Response:
Hello, This scanner will not be supported on windows 8, all of our USB 1.0 technology scanner will no longer be supported beyond Windows 7.
Wendy
1helpful
I replaced the passenger side front door regulator and the window still wont move. It seems to be dragging in the track. I can move the motor and it seems fine and i can move the window manually and see...
If you take the motor off, you will see a metal cover behind the gear, inside that cover is some plastic gears that have rubber insulators. Most likely those insulators are broken up and when you put a load on the motor such as working the window, the insulators allow the two gears to disengage. Look on ebay for ford window motor repair kit.
1helpful
Instruction manual for Prime Film 1800U scanner
yes the driver can work on Vista systems, you can find manuals and drivers here:
http://www.scanace.com/download/Cyb_X_SF.htm
cheers
1helpful
I loaded the film but display window shows a flashing zero
Go ahead and try anyway. A ruined film is far cheaper than a useless camera or a professional repair. In any case, if the film hasn't loaded properly it will only be the first short length of film which is ruined. As this is a newly loaded film you haven't any risk of losing any undeveloped photos.
Auto spooling film systems are great when they work, but sometimes are a real pain and some cameras seem really picky about having a film leader of precisely the right length. See if you can engage the the film onto the spool manually.
1helpful
No signal
Do you get a signal if you stand outside?
If you do and you can't get a signal inside the house then you may be in a building with a high standard of thermal insulation using aluminium foil in the walls and roof (depending on the country you are in). Modern windows use a thin copper film (kappa glass) to reflect infra-red radiation back into the room but it also blocks radio signals.
Peter
6answers
FILM REVERSAL
does anybody know a freakin solution????
Top Insulation Experts
ADMIN Eric
ADMIN Eric
Greg Bjorn
Greg Bjorn
expertpc
Level 1 Expert
Are you an Insulation Expert? Answer questions, earn points and help others
