HP PL4260N 42 in. Plasma HDTV Logo
cleopatra Posted on Feb 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp pl4260n 42in plasma not responding
Tv will not respond to the side buttons and will not respond to the remote. changes inputs on its own, goes to hdmi on its own. the remote is not the problem. turns on & off by itself
Level 3:
Top Expert:
  • HP Master 76,851 Answers
  • Posted on Feb 05, 2014
HP Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007086
Points
237762
Sounds like a main board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Mar 20, 2009
SOURCE: Black screen on HP PL4260N 42? Plasma HDTV
The problem is the "Y-SUS" board. It is inside the set on the left side with several aluminum heat sinks, under the left side brace bar. You can order this board from Union Electronics at www.ued.com .Search for part number: TNPA3243AB-PA
It lists for about 115$
lloydainey
  • 9 Answers
  • Posted on May 23, 2009
SOURCE: Looking for replacement circuit board for HP TV
On ebay for less than $100
Anonymous
  • 227 Answers
  • Posted on Jun 24, 2009
SOURCE: No Image on PL4260N HP Plasma Tv
HOLA HUMBERTO, SI ESTAS EN MARYLAND YO TE PUEDO REPARAR ESE TV POR MUCHO MENOS DE ESO. BUENA SUERTE [email protected]
skistockli
My2CentsWorth
  • 73 Answers
  • Posted on Jul 11, 2009
SOURCE: I need help finding a fuse for my HP PL4260N
You will be lucky if its actually the fuse. This HP TV is known for a circut board problem that was actually A KNOWN PROBLEM and HP still sold the TV's anyway. They were fixing the TV's for Free up until Dec when they decided to stop. You might want to contact the group that is taking legal action agaist HP for Selling a known defective product.
Anonymous
  • Posted on Dec 13, 2009
SOURCE: I have sound, but No picture (HP PL4260N) plasma
Solution: buy a TV made by a TV maker, not a PC maker! eg: Sony
VW37L 37 in. LCD HDTV input button wont work
Have you find out if the problem is with your remote control? For instance, you are able to control your TV using a Universal remote control. My 32" Vizio TV had a similar problem, initially thought it was related to my remote control but in fact the TV didn't respond either to an universal remote control of my SAT receiver that I eventually use to just turn on and off the TV. I've found out that the problem was with a little board on the TV located at the left down corner viewed from the front side of the TV and that receives the signal from the remote control. I found the board on ebay for about $5, replace it and the TV responded again to both original and universal remotes.
HP PL4260N source list entries are all "Cable"
Video board is most likely damaged from a electrical spike, you may try looking at the capacitors on the boards inside the tv and see if they are damaged capacitors are an easy solution to problems some of the time.
1helpful
2answers
2answers
2answers
The TV does not respond to the remote control nor the buttons in the front panel
Sounds like power supply switch needs to be changed to normal setting. If you are comfortable with electronics i will talk you through it if not you will need a tech or back to cosco it goes if you have a warranty.
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
