SOURCE: My nordic track treadmill's walking belt stops
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
SOURCE: speeds up and slows down
Dear Sir:
Please adjust the sensor speed for the main motor. Of course I am recommending Very Strong to RUN the software calibration for easy diagnose and troubleshooting.
Otherwise see my personal TIPS, for diagnosee
Trouble.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a
B) Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank
down the belts and on treadmills, tighter is not necessarily better. The tighter the belts, the more the drive system has to work to keep
everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3" without
straining. Tighter belts should be loosen but make sure you don't create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating
position. Loosen the belt if too tight. Make sure to test for slipping
and if it does with the proper tension, replace the motor belt.
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
sincerely.
E. CUADRA
