Question about Kipor Electrical Supplies
Kipor 6700ta po5 code problems , diesel silent generator
    Novelist:
    Habit-Forming:
  • 118 Answers
1. Check the voltage of battery whether is 12V or 24V; 2. The voltage of battery is low when the generator is still, then it is necessary to dismantle the battery and charge the battery with charger.
3. If the voltage of battery is low but the generator is running, it indicates that the diesel engine driven charger doesn't work; then it is necessary to stop the engine to check the fan belt.
4. if the fan belt is not loose, please check the charging AC diesel engine driven charger, please refer to Manual for Diesel Engine.
5. If the battery can not store the electricity, please replace the battery for a new one. https://www.dieselgeneratortech.com/generator-sets/discovery-and-elimination-of-faults-of-the-control-system.html
Posted on Sep 30, 2018
3 Suggested Answers
SOURCE:
adnanbhatti
  • 1188 Answers
SOURCE: Kipor 6700TA displaying charge fault (P5)
Check for loose or rusty battery cables. Unscrew the rear cover and locate the red battery wire. Disconnect it and, using a multi meter, check its resistance: it should have a very low value. Do the same with the other wire.
Start the generator and remove battery wires. If the voltage between them is zero then a fuse is blown.
Next open the front panel (where the display is), there you will find two blue wires with covered fuses, check and replace those fuses if found faulty.
If the problem is still there then it could be the charge regulator. Open the back cover by removing the six nuts. Near the edge you will find a component with silver cover resembling plates. There are three wires leading from it. Check resistance between these wires (one by one) and its body: it should be infinite, if not then replace it. remove the charge regulator and take it to a generator spare shop. The person there will further inspect it and will tell you if you need to replace it or repair it.
Hope this solves your problem.
Thank you for using fixya!
Posted on Aug 20, 2009
  • 5603 Answers
SOURCE: Hi, My Kipor 6700TA wont start. Battery died or fuel issue?
It sounds like your unit may not be charging the battery properly.
Try charging the battery and see if it responds properly. If it does, then check the charging circuit. This OFTEN involves a rectifier module which is usually about 1 inch square with four leads. OFTEN there is a fuse, sometimes within the generator housing (stupid place) which protects the low voltage winding.
Here is a hint: Most of these engines have a compression release on the top that one can press then crank up to speed and release. This takes much less effort on the battery. Some have a panel held by bolts. I put hinges on mine for easy access.
REMEMBER the battery is being drained WHILE the unit is running to hold the fuel solenoid open... so if charging isn't working the battery will die.
Test: You should see about 13.75 to 14 volts across the battery when properly being charged while running.
Posted on Apr 06, 2010
Kipor generator 6500 starting and stoping after few minutes running what could be the problem Diesel model
Im taking it as the engine is cutting out?
Is this a diesel model?
Try, low oil cut off, fuel tank not vented correcly, fuel blockage.
Feb 25, 2018 | Kipor Electrical Supplies
Generator kipor 6700ta, run for a few second and stop, any solution?
hi
you may want to check the filter in the tank if one is fitted check damage fuel line , insure that fuel tank cap breather hole not blocked and injection system
Dec 09, 2017 | Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
How or where can I get another fuse and its cover for diesel Generator KDE 6700TA. I live in Mallorca, Spain. m
try contacting the manufacturer of that unit .or a good electronics supply house . not being in Spain I have no idea what name they might go by there
May 30, 2015 | Diesel Electrical Supplies
Why unit keeps shutting down after it starts.
Your question is general without specific details. Any one of many things will cause your generator engine to stop running.
Is this question about a Kipor KDE5000TA? If so, your generator is powered by a diesel engine. There are safety shut downs built into the generator to protect the generator head and engine. Do you have any fault codes showing on your control panel display screen? (Trouble codes P-01 through P-05 will be displayed if there's a detected fault)
If you have no fault codes, then you likely have a fuel problem. Do the obvious:
  1. Visually check the fuel level in your tank. DO NOT rely on your fuel gauge. It may be stuck or otherwise not working.
  2. If you have fuel, check your fuel filter. It may be clogged. If your fuel filter is good, you may have water contamination.
  3. Drain your tank and refill with fresh #2 diesel fuel. I use "Diesel 911" with a biocide to prevent water contamination and bacteria growth in my fuel.
  4. Make certain your fuel oil supply and return lines are clear, not leaking, and the fittings are tight.
I know I'm shotgunning, peppering the target. However, I don't have enough information to zero in on a specific area where the problem could be. Good luck!
Apr 26, 2015 | Kipor Generator Diesel Kde5000ta
Kipor kde 6700ta GENERATOR
There is, on most generators, a fuse of approximately 8Amps in series with the charge system for the battery.
If the generator produces AC and there is no charge to the internal battery, I would suspect the altenator winding, diode pack or regulator.
Nov 14, 2013 | Computers & Internet
Apr 06, 2010 | Electrical Supplies
Aug 18, 2009 | Electrical Supplies
KIPOR KDE 6700TA 5KVA Generator
forget about the display read the manual and find out how many volts are needed to charge the battery....then
get a voltometer and disconnect the terminals from the battery and connect them to the voltometer while the generator is running...
find out what the reading is...if the reading is zero (0)...then post a problem on (no out put)...
if not.....then there has to be a mistake...
if it reads a voltage thats too low..then you AVR card is burnt out (AVR card is located in the other end of the generator (beyond the stator-side cover)...
Aug 04, 2009 | Kitchen Appliances - Others
Electrical Supplies Logo
411 people viewed this question
Top Kipor Electrical Supplies Experts
Vernon Taylor
pawnpower
Wayne McNeil
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
