If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
This camera is equipped with the TFT micro display which has about four times the resolving power (number of pixels) of past models.
As a useful mode, it has "Quality mode" of 640x480 pixels (30fps) and "Motion mode" of 640x480 pixels (60fps).
Quality mode: The high resolving power is the most important. The detail parts can be recognized, and it is helpful when the focus is checked. Difficult focusing on the past models can be easy without enlarging.
Motion mode: It is for recording the moving subject. The same number of resolving power is displayed as the quality mode. However, as the pixels are interpolated from 640x240 to 640x480 in Motion mode, the image in the Quality mode looks better.
The details for each record mode are as follows:
RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth.
TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer.
SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored.
HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ.
3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode.
SQ1/SQ2: SQ1 is used for resolutions above 1600 x1200 and SQ2 is used for resolutions below 1600 x1200. For both, you can choose high compression to reduce noise or normal compression to save more images.
SQ1: SQ1 uses the highest compression for resolutions greater than 1600 x 1200. You can choose high compression to reduce noise or normal compression to save more images.
SQ2: SQ2 uses the highest compression for resolutions less than 1600 x 1200. You can choose high compression to reduce noise or normal compression to save more images.
