What is the cause for this error code EH1 on AWD-703HCTP Sanyo washing machine?
A possible answer is that the machine runs for a short while and then stops. So check water supply filter is not blocked, pipe kinked, outflow pump clear and that the filter is clear.
THE biggest cause for any machine not to work is actually the pump out pump and filter are jammed probably thru stuff not removed from clothing, coins (will nicely smash holes in machine) paper and fluff. Also check for overloading, frankly most people overload machines. Just a thought, nobody has turned the water off!
Your error codes may be on the machine or service booklet. The above are the most frequent generic problems.
