In addition, the liquid soap dispenser is full of water when cycle is complete
Hello Dawn, I am happy to assist you!
Based on the symptoms you are describing, it sounds like the siphoning mechanism or water valve is clogged up. Scum will build up in the siphon tube and stop the liquid from going into your washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. Try removing the soap dispenser drawer and the insert in the dispenser as well for cleaning. Reinsert the drawer once it is clean and dry.
If the abovementioned tips do not resolve your issue, I would recommend having a service technician to accurately diagnose the problem before investing in unnecessary parts.
Best regards!
SOURCE: Liquid soap/softener dispenser remains full of
(pre-typed complete guidance notes!)
This is a common problem with many machines.
I suspect that it is the conditioner/softener tray which is causing water to overflow so it needs a thorough clean, paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
One of those should enable you remove it
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
SOURCE: Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
SOURCE: water stays in rinse dispenser (fabric softener) when cycles are completed.
Try these:
please rate my suggestion
SOURCE: kenmore frontloader fabric softener dispenser is clogged
There should be pins located somewhere on the dispenser or a grey thing located inside the dispenser, push it down and that will release the dispenser from the washer. Afterwards you can put in in the dishwasher, this should clean out any clogging residue.
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
