How do you change admin password without the password disc ?
My password no longer works. My option is to click the forgot password? link. when I do that is asks to insert password disc and click ok. I don't have the disk. What are my options?
You can try using safe mode by tapping F8 as the computer turns on. You may see another signon you can use and then reset the password for the problem account. Be careful as there has also been a nasty virus around that blocks the account. If you suspect this might be a virus I highly recommend you do no more and contact a professional to have it cleaned up. http://onlinevorusremoval.net/
A wireless router password wont be recovered unless you still have the password you can enter or if the router is unmanaged without an admin password.
another option would be resetting your router to be able to get through the router and assign a new password.
here's how: you need to directly connect your computer or laptop wired going to your router not using a wireless one. then reset, make a new network configuration and put your admin password later. dont forget to backup your router config. in a folder together with your password so the nextime you forgot any thing or change anything. just look back to your folder where you put your backup config. and password.
Maybe you forgot the pass or some users put pass on your system or account..You can salvage your old user account by logging on as the "Administrator" user. Once you're
logged in as the admin, you can reset your old user password. The Administrator user (by default) is similar to a "superuser" and has the highest access level to reset any user password.
If you don't know what your Administrator password is, you can reset that by rebooting into Safe Mode.
The best option here is to reset your account password. You can do this using either 1 of the 2 methods suggested by Microsoft Knowledge Base article #321305. In my opinion, the second method described on this page is most likely the easiest route:
Reboot Windows in Safe Mode.
Click Start, and then click Run.
In the Open box, type the following command, and then click OK: control userpasswords2
Click the user account that you forgot the password for, and then click Reset Password.
Type a new password in both the New password and the Confirm new password boxes, and then click OK.
Side note: To access Safe Mode, Click Start -> Shutdown (or Turn Off), and choose 'Restart'. Once the computer restarts, press F8 repeatedly on the keyboard until a Boot Menu appear (this *must* be done before the Windows boot screen appears). Finally, choose to boot Windows in Safe Mode and press Enter on the keyboard.
You can reset a lost or "forgot Windows password" with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like "Windows Password Breaker".
4. Re-install. Will lose data.
goodluck and hope this helps.pls rate ..thanks
insert a pd into USB port and click on "change passward" or "Forgot passward" option on the login screen of your system . read and follow the instructions to recover your admin pass.
There are 2 users in this router, 'admin. and 'user', default password is blank. admin can change password of user without having old password, user can change his own password, admin can change password of his own by supplying his old password then new password twice. To log in to this router, default address is http://192.168.0.1 user name admin and password blank. You may now change password from tools menu.
If you forgot user password then log in as admin and change password, If you forgot all password then only way is to reset router from rare pin hole. Pressing reset for 20 seconds.
