Motorola Mobility TZ710 Bluetooth Car Kit Speaker Logo
A
Anonymous Posted on Feb 04, 2014
How do you pair the 710 to a handset - Motorola Mobility TZ710 Bluetooth Car Kit Speaker
I can not use the handset. I can use the speakerphone. I put new batteries in the handset and the bottom of the phone. When I pick up the handset I do not get a dial tone, it squeakes or beeps.
You need to pair the handset to the base unit, hopefully you still have the manual. Because you didn't give a brand/model I can not give directions on how to pair the handset to the base unit.
There should be a menu button located on the base unit, just push it until pairing (or something like this) shows and you should be able to complete the pairing operation.
Hopefully this will head you in the right direction.
Mar 06, 2011 • Cell Phones
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
How is it turned on
Press and hold button on face of device for approximately three seconds. Light should begin to flash.
To pair this headset, press same button for approximately five seconds until light comes on and stays on. Locate the device using your handset/phone's Bluetooth operation.
1helpful
Cannot place LG-HBM-710 in discoverable mode
It sounds as if the device is not paired with your Chocolate. Press and hold the button on the face of the HBM-710 headset for approximately five seconds, or until the light comes on and stays on steadily, then discover the device with your handset's Bluetooth screen. Once it shows up in the list of devices, select in and pair it with your phone.
6helpful
2answers
My headset will not pair with my new cell phone
First, open the phone's Bluetooth screen. On the HBM-710, press and hold the button on the face for about five seconds, or until the light comes on and STAYS on. Now find the headset with your phone and pair it.
Hope this helps!
33helpful
HOW DO I PLACE AN LG BLUETOOTH HBM710 IN "DISCOVERY MODE" ?
Just came across your question while searching for the same answer - Here's what I found out:
When it's off, press and hold the on button for 5 seconds - it'll turn on, but keep holding until you hear the short beep - the light's on and you're where you want to be. Here's the full text that I found from the manual:
-With the HBM-710 off, press and hold the PWR/END button for 5 seconds
(You will hear a short beep and the LED indicator will stay red, when the device enters pairing mode)
-Using your handset, find the "Bluetooth menu" and "search for" or "add" new devices
- Select "LG HBM-710" from the list of devices and pair it with your headset
- When asked for the Pass/PIN code during the pairing procedure, please enter "0000" (4 zeros)
- Once pairing has been completed successfully, you will hear a beep
- After pairing successfully, be sure to "connect" to the LF HBM-710
- If you want to pair with other devices in the future, the headset must be in "Pairing mode"
- If it will be not connected the "Pairing" for three minutes, it will be turned off.
7helpful
How do you put in pairing mode?
Here's how to get the LG HBM-710 Bluetooth headset into pairing mode:
While the headset is OFF, press and HOLD the power button. CONTINUE to do so even after it has powered up. About 3-4 seconds after the startup beeps there will be one more beep. Then, the red light will go solid.
You are now in pairing mode! Hooray!
Go through the necessary 'Add a Device' steps on your cell or whatever and you should be G2G!
LG HBM 710
Sounds like someone "hacked" your headset and changed the code and display name. if you don't know the new code then my only suggestion would be head to your local distributor (probably a Verizon store) and ask them to reset your headset for you.
1helpful
My lg 710 passkey won't work help please
hey yeah i had the same problem and so i tried all the other known passkeys and 1234 worked for me. so good luck hope it helps.
Top Motorola Mobility Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
john h
August Brown
August Brown
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
