SOURCE: saw cuts then stops chain still goes around bar then seems to catch agian then cuts
sounds like the clutch is starting to go out. i have one just like it and the same thing happened to me
SOURCE: Can not keep chain on bar. Tried 2 different
The inside part of the chain are called drive links. I think when the chains came off the first time (loose chain?) some of these links were slightly deformed (burred). Take a flat file to the burrs on the sides of the drive links. Once repaired keep your chain properly tensioned.
Chain adjustment
Lou
If no burrs please repost. This has piqued my interest. I think a brand new chain will operate correctly.
The inside part of the chain are called drive links. I think when the chains came off the first time (loose chain?) some of these links were slightly deformed (burred). Take a flat file to the burrs on the sides of the drive links. Once repaired keep your chain properly tensioned. Your saw is fitted with a chain catcher (page 9 of your manual), it did its job and kept the chain from smacking your leg (were you wearing chaps?). Burrs are often created when this happens.
Chain adjustment
You can download your "Operator's Manual" and an "IPL" (exploded parts list) here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Lou
SOURCE: Hot bar loose chain
Hello Sam;
Sounds like your oiler is not operating, try this please:
Oil System Plugged:
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL). Post back (below) with a model and serial number if no ooze and I will provide an IPL.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Remove the bar and chain from the engine. Clean the side of the engine where the bar fits, start the engine and run fast for several moments. Oil should ooze out of a port and run down the engine side. If nothing, then the oil lines, valves, tank filter, and the oil pump (behind the clutch assembly) should be checked for plugging, breakage, or other problems. If oil comes out, then clean the oil holes in the bar drive end including the two small holes that lead from the larger holes out to the chain groove on each side. Clean the entire chain groove. Oil and check the end sprocket for smooth, relatively free turning. Compressed air is very useful for cleaning these parts. Reassemble bar and chain making sure the adjustment tang drops into one of the large holes--you may have to back off the adjustment several turns to make this work. Make sure the chain cuts toward you on the bottom run and install the clamp nuts/bolts finger tight. Adjust the chain until it pulls up to the bar and you can turn the chain by hand. Run a line of oil around the chain to pre-lube it. Tighten the clamp nuts and retest the tension again. If ok, start the engine and run for several minutes, then place the tip near some cardboard and run at speed for several moments--it should throw off a thin line of oil. Make sure the chain is fully sharpened then try a few cuts. It should cut smoothly without any undue pressure from you. Hope this helps!
