How to remove door
Without seeing it don't know which you have open the door look at the hinges if you have what looks like little levers that fold down then raise them up fully start to close the door slowly they will catch the levers raise the door slightly and pull out if you have the other style open the door fully look at the hinge you should see a small hole insert a small screw in each hinge follow same procedure.
SOURCE: replacing inner door glass kitchenaid kebc208ss
Click HERE for the service manual and refer page no. 21-22
This will solve your problem.
Goodluck,
Please don't forget to rate me as fixya..
SOURCE: replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe
inner screws. Keep all set of screws ordered, and take note of theorder
you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
"removed the door from the
oven by releasing clips attached to the door hinge -- very nicely
engineered. Removed about 6 philips head screws to allow the door
assembly to be taken apart for access to the glass. Lifted out the
broken glass, cleaned the inside of the door, installed the new glass,
reassembled the door (a two minute project), and reattached the door to
the oven. Cleaning the inside of the door"
"I removed the oven door by
lifting it off with the hinges. Disassembled the door parts one at time
making sure I remember where I removed the screws until I am able to
get to the broken glass. The most difficult part is making sure that
the insulation strip & the gasket stayed in place after I replaced
the broken glass & doing the reverse process of installing the
parts together. Relatively easy process as long as you remember where
the parts go. When in doubt, I had to refer to the pictorial of the
disassembled door shown on your website.
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
SOURCE: kitchenaid kebs107dal4 how do you remove oven door
This OWNERS MANUAL describes removing the door on page 45.
The PARTS MANUAL will give you expanded views and part numbers.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: How do I replace door
Its not very hard.
1. Open the upper oven door.
2. Raise the door hinge tabs to the "unlocked" position.
3. Close the oven door to within several inches, lift and pull out on the hinges, and remove them from the oven slots.
Click this link to see the door and door hinge parts.http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0103109-00003.png
Part number 2 is door hinge.------------
To see more diagram.Please click the link below:---
http://technoanswers.blogspot.com/2011/04/how-to-remove-door-hinges-on-kitchenaid.html
This should help.Thanks.Helpmech.
there will be two hinge latches that you flip to stop the door from closing. This will allow you to push the door in and then pull out the bottom. I do not suggenst using the handle as it may cause damage. use one hand on either side of the door, push the door shut and then lift up a bit and pull the hinges out of the holes.
