I would truly call in for service. Copiers require a trained tech to replace the fuser. Trust me I work in the IT industry. Have a trained tech fix it.
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
Sir, I have Document Centre ColorSeries 50 In this machine Scanner is
not working, in the Machine Display showing : Error... the Fiery Server
Interface timed out, please, check the Fiery. Please help me
There is an actuator that is knocked off its mounting.
It is towards the front of the machine, right by the output rollers.
It would be about 3 inches long and have a couple of flag shaped lobes on it. All it needs is cliped back into place. There are 2 metal tabs with holes in it to insert the ends.
That is your problem.
