Computers & Internet Logo
Posted on Jun 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Avast In the work, I use a PC not connect to the net and installed with avast antivirus, after long period when the pc turned on and win xp sp2 operates message appear to update it or uninstall it. The problem is , when windows operates and I want to open any partition of the hard (C,D,E,F) , not open , not respond to (double click or right click then open) , I tried to remove the avast from the control panel or from the start menu but fail , finally I use the program (Your Uninstaller Pro 2008) and remove it , then I turned off the pc , and on again ,, the message of the avast (I explained above) appear again , the avast also exists in the start menu and in the partition C in the ?program files? folder , I try to delete it from it but cannot , (note :avast does not exist in the control panel ) Please help me to remove the avast completely from the pc , I want to remove it from c , start menu and the message at the beginning ,,, thank you
  • 3 more comments
  • sherin_fahad Jun 07, 2009
    thank you , i use the autorun virus remover, find more than 10 autorun virus ,, but still i can not remove the avast antivirus ,, when i try to delete it from C (program files) folder , the message appear " can not delete Aavm4h.dll: access is denied , make sure the disk is not full or write-protected and that the file is not currently in use "
    please help me what to do to remove the avast completely
    waiting for your reply ,, thank in advance
    please answer me
  • sherin_fahad Jun 08, 2009
    Hi ,, Previously I told you that (I tried to remove the avast from the control panel from add or remove program , but fail , finally I use the program (Your Uninstaller Pro 2008) and remove it )
    now the avast does not exist in the add or remove program ,, but when the pc turned on ,, the message of the avast to update it or uninstall it,appear again
  • sherin_fahad Jun 09, 2009
    please help me
  • sherin_fahad Jun 15, 2009
    thank you so much
Anonymous
Level 3:
  • Master 790 Answers
  • Posted on Jun 06, 2009
Anonymous
Master
Level 3:
Answers
790
Questions
6
Helped
225094
Points
1965
Hi
i think you have autorun virus! and you need the autorun virus remover! get this autorun anti virus remover clickhere
Thanks!
  • Anonymous Jun 08, 2009
    Hi
    Just go to my computer then click the ADD or REMOVED PROGRAMS then click the avast as remove Thats it!
    Thanks!
  • Anonymous Jun 12, 2009
    Hi
    ok please install the HIJACK Software!http://download.cnet.com/3001-20_4-10227...
    Thanks!
I have downloaded avast free antivirus but it denied to run or install.i have no any antivirus in my PC now.
Which Microsoft operating system are you using - XP - Vista - / or ????
Here is the link to Avast where you can find/download the free version:
http://download.cnet.com/Avast-Free-Antivirus/3000-2239_4-10019223.html?part=dl-85737&subj=dl&tag=button
I am running Microsoft XP servicepack 3 and it is running without problems at all.
You tell that it denied to install ! Please indicate what message you get while installing - eventually a failure description given by the operating system
Regards
Waiting for your reply.
If problem can not be solver for some reason you could use AVG instead.
here it is - the free version:
http://free.avg.com/ww-en/homepage
Regards
6helpful
2answers
Download older version of Avira Antivir
Why xp SP1??.
If you dont update your OS, even with the best Antivirus you will be in big trouble with security breaches/holes.
IF your copy of windows will not pass the WGA then you are out of luck with Avira . Avira needs SP2 so you could try AVAST, its min requirements are.
Processor Pentium 3, 128 MB RAM, 100 MB of free hard disk space
Microsoft Windows 2000, Microsoft Windows XP/Vista/7 (32/64 bit)
2answers
I have a dell inpsiron 2200 notebook which i just installed a new windows xp sp2. Before the installation the local area network connectioon was showing but after installation it does not appear again. i...
problem is the win xp operating system
There are no drivers for what you want and the win xp has not been supported for a long time
In fact for so long that win 7 is now in the same boat
I have notebook Compaq 6715b with Windows XP (no SP2). Sound doesnt work. drivers from HP official site not working
trust me, the fault is from the win xp SP2. I am saying this with confidence and out of experience. Except if the audio drivers you downloaded is for win vista.
While running the Win xp, some files make have skipped/not installed which is making the sound not to work. Or maybe you have initially installed a wrong audio driver.
To solve this problem. you have to re-run the win xp, if possible, use another xp Cd, maybe not Sp2.
After installation, let the audio driver be the fist thing you install.
Take care.
2answers
PC shuts down without warning and then re-boots automatically about every 20 minutes or so .
you have an internal error in system files. technicaly the only solution is to restore win xp using cd provide by manufacturer and install a good antivirus, (i will recommend avast home edition works great and free)
I am using windows sp2 os.i am not able to install avast antiviru
If the antivirus is not genuine but one thats downloaded from the net, then most probably it itself caries a virus with it hence your PC is rejecting it. Try to install a genuine antivirus and see the behaviour of the PC......sodeep
2answers
Task bar hangs
http://www.avast.com/eng/download-avast-home.html
downlaod avast antivirus from here then install in computer then update it then scan your computer i boot time schedules mode.
then when u find virus press "1" to delete it.
1helpful
2answers
Restarting system when ever i am scanning
Seems to be some virus problem, try installing Avast.. during avast installation you will get a window prompting boot at scan click on Ok and once installation is done it will prompt for restart and your system will be scanned as it is restarted.
Let me know if this fixes your problem.
10helpful
5answers
Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
Uninstall WIN XP PRO UPGRADE
Unfortunately you cannot "Uninstall an Upgrade" - Do you refer "Upgrade to SP2/ SP3 or WIN98 or WIN2000 to WIN XP? Please clarify? Regardless - you will have to reformat your PC and purchase a new license key as you have used the one on another PC or you should void the license on that PC and use it on the original PC.
In short unless you do not use the license key or purchase a new one, your PC will not log-in after 30 days and you will then have to activate again using telephonic assitance (if you modem and internet connection were no configured before the end of you activation period. There is now Un-install function. Sorry.
Grand Canyon Tech
Grand Canyon Tech
