My laptop has a switch to turn on bluetooth and wireless. the laptop came with windows vista but i have since upgraded to windows 7 home premium. when it was running vista when you toggled the switch it would tell you which service was turning on or off. with windows 7 it no longer shows what the setting is. can you tell me from reboot what each toggle of the switch means. i know the first toggle turns only bluetooth on. thanks
SOURCE: upgrade vista home premium
As per my knowledge, there is no version of Vista called Vista Professional like in Windows XP.
Make sure what is the version to which you want to upgrade to from Vista Home Premium to Vista Business or Vista Ultimate.
The available versions of Vista Operating Systems along with the features supported from the Link below :
http://www.microsoft.com/windows/windows-vista/compare-editions/default.aspx
However, if you want to Upgrade the current version of Vista to a higher version like Vista Business or Vista Ultimate, you need to purchase Vista Anytime Upgrade kit from any retail store or directly from Microsoft.
You can find the required information related to Anytime Upgrade Kit from the link below :
http://www.microsoft.com/windows/windows-vista/get/anytime-upgrade-overview.aspx
However, make sure that you had created the Recovery Disks for your notebook using which you will be able to reinstall the preinstalled Operating Sytem along with all the Preinstalled Applications and Drivers after which you need to use the Vista Upgrade Kit to upgrade to higher version of Vista.
However, if you are currently having a 32 Bit Vista preinstalled in the Notebook, it is not possible to upgrade to a 64 Bit Vista since you can upgrade only a 32 Bit of Operating System to a higher version of 32 Bit Operating System and a 64 Bit Operating System to a higher version of 64 Bit Operating System.
Hope this helps....
SOURCE: connect bluetooth phone to hp dv9000
have a look at this manual:
http://h10032.www1.hp.com/ctg/Manual/c00186949.pdf
hope this helps
kind regards
SOURCE: Latitude d430 my wifi will not turn on
Try reinstalling driver for WiFi and then configure and reboot the machine.
SOURCE: cannot connect to wireless internet
make sure you can detect networks
If by mistake you disabled the wireless, you can re-activate it by pressing fn-f11
Good luck
SOURCE: Toggle Between Laptop and Monitor
Fn + F5 toggles the display output, the trick here to wait each time you hit this combination because it goes through several options. Hit it once and it may want to go to just the external, then both the laptop screen and the external. etc. Now Fn + F6 turns the backlight bulb off on the internal monitor to save energy. Now I am giving up the link to your service manual, it is in PDF format so you can make a copy for yourself and keep on the laptop, print it or save it to a flash so you can reference it later. I believe if you take the keyboard off and disconnect the video lead on the left side where the display plugs into the motherboard, then when you power the laptop back up it will default to the external cord and you can use the laptop without any switching. That is what I am doing with an Aspire 5920 that I am rebuilding. Good luck, ParrotHead PC Repair
Just copy and paste the link below to you internet address bar and hit enter.
http://tim.id.au/laptops/acer/aspire%203680%205570%205580.pdf
