HP Pavilion DV6700Z Notebook Logo
Anonymous Posted on Jun 06, 2009
Connect to a tube TV
I want to connect this laptop to a Tube TV to mirror the monitor.The TV has RCA and YPbPr inputs only. No S-Video, no HDMI. My Laptop has an ATI Mobility Radeon HD4530 Video card (Does this card have TV Out?/capable of displaying on a TV).
Outputs are HDMI or VGA. I have a cable that has a VGA plug on one end and RCA on the other I have tried everything I can think of to get it connected. I also have a cable with HDMI one end and RCA the other, but this cable cannot be used for HDMI input (can't use it on the computer end only into a HDMI TV)
I have seen HDMI to YPbPr converter boxes on EBay but don't want to pay $50 to get this setup working.
Is there another way and would one of those HDMI to YPbPr converters work (COMPUTER VGA to HDMI CONVERTER YPbPr to TV)
Anonymous
Level 3:
  • Master 822 Answers
  • Posted on Jun 06, 2009
Anonymous
Master
Level 3:
Answers
822
Questions
Helped
240424
Points
2570
Hi mr. pavilion dv6700z. i have the same problem before but after i tried and use my genius mind. i made it. and the television is working in my laptop as a external monitor. pixel is good. just connect in card video out to video iput to television. [email protected].
How to connect asus p1801-t to tv ?
This PC is equipped with a NVIDIA GeForce GT 630 2GB DDR3 VGA/DVI/HDMI PCI-Express Video Card. This means if your TV has an HDMI input connector you can directly connect the pc to the Tv with an HDMI cable and select the corresponding graphics monitor connection in the Display properties. Alternatively if your tv has only got a VGA input that can also be used from the PC and you can connect the speaker or headphone audio output to the audio input of the TV with a suitable 3.5 headphone to RCA adapter.
Have Blu ray player with Wi-Fi and need to connect to this TV
If you can't find a special wire for that you may need a box that converts video from and to whatever video wires you want http://dx.com/p/component-video-ypbpr-to-hdmi-converter-box-with-spdif-audio-input-29772
Connect toshiba satellite l305-s5919 to tv with vga to rca cable
that particular model of computer l305-s5919 has RGB component out while the tv seems to be rca input.
does the tv have component in.
you may find an adapter like this might work
http://www.ebay.com/itm/Ypbpr-component-to-Composite-AV-RCA-audio-video-converter-with-power-supply/272260592065?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D44770%26meid%3D75516a845eb841a3bec53062c7dfac66%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D230912528485
1helpful
2answers
I have a HP m7570n. How do I use a flat screen tv as a monitor
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
How do I connect my laptop to tv to use as monitor
It depends on the laptop and the TV. If both have a VGA port, then use a VGA cable between them. Make sure the VGA port is enabled on the computer (possibly in the BIOS) and then set the monitor properties. You may need to reboot the computer to get the TV on.
If the TV has HDMI input and the laptop also has an HDMI port then you need to check the TV specs. Some HDMI ports can accept a signal from a computer (often labeled HDMI/DVI) and others don't. If the HDMI port is compatible with a computer source, then use an HDMI cable between the two. Again make sure the port is active. If TV's HDMI port is not compatible with the computer, you will need a converter.
If the TV doesn't have a VGA port (and the laptop doesn't have any video port other than VGA), then you will need a VGA to component video converter (or VGA to composite video) depending on the inputs of the TV. See http://www.svideo.com/pctocomponent.html for some converters.
Note: the converters are needed since computers output in a different format than the TV input understands. For analog, the computer is RGB and the component video is YPbPr.
A few media PCs might have a TV out port. This would eliminate the need for a converter. Check the specs for the cable you need.
I hope this helps.
1helpful
Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
2answers
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
2helpful
Connection problem with Denon 589 and direct tv
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
