The low water level sensor is in the overflow bottle, not the overtemp sensor.
The overtemp sensor will be on the motor somewhere.
To check you have the right sensor- short the sensor to ground and observe the overtemp light operation.
You likely have a faulty over temperature switch sensor.
Hi Stingtas,
I cannot identify what you mean by "Hydraulic sensor switch" - need more explicit description.
You may need a special spanner or tool, I'm not sure at this time. Maybe remove an assembly to gain access.
I suggest you join the Ford Forums Australia- its free, and there you will find the detailed info you need. See link below:-
http://www.fordaustraliaforums.com/forum...
Regards,
Johnb
Hi John,
Thanks for the info,I must have been looking in the wrong place for the temerature sensor,
The other problem i have with my Au falcon is,
how do i remove the hydraulic sensor switch as i need to replace,it is leaking fluid,
there appears to be no room to turn a spanner,
Thanks again for putting me right with the temperature sensor,
Cheers Tony.
