Question about Dell PowerEdge Computers & Internet
Power is 2950 i912 sel full
How to clear
    New Friend:
    Problem Solver:
  • 5 Answers
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
Posted on Oct 01, 2014
SOURCE:
Where is poweredge 1800 display led connector
http://www.dell.com/support/troubleshooting/us/en/19/KCS/KcsArticles/Print?he Embedded System Management (ESM) log - also called System Event Log (SEL) or hardware log - reports potential hardware problems in Dell PowerEdge servers. Sometimes, simply turning off the server and disconnecting it from the electrical outlet will remove the error message. Wait approximately 10 seconds, and then reconnect the power cable and restart the server.
Other times, you will need to clear the ESM log to remove the error message. For instance, error code SEL FULLindicates that you will need to clear the ESM log. (You will lose the server's event history.) There are different ways to clear the ESM log.
To use DSET to Clear the ESM Log
  1. Download and open the DSET utility.
  2. Click the plus (+) next to System, and then click the plus (+) next to Logs.
  3. Click ESM to highlight it.
  4. Click Clear ESM Log located in the upper-right corner of the page.
To use OpenManage Server Administrator (OMSA) to clear the ESM log
  1. Start OpenManage Server Administrator (OMSA).
  2. Log in to OMSA by entering your username and password, and then press Enter.
  3. Click the Logs tab, and then click Hardware.
  4. Click Clear Log located next to Options.
To use Dell IT Assistant to clear the ESM log
  1. Start IT Assistant.
  2. From the middle System Tree bar, select your server by clicking it.
  3. Click the Logs tab, and then click Clear Log in the upper-right corner of the page.
Find your Dell PowerEdge server model in the chart below for other ways to clear the ESM log:
PowerEdge server model How to clear the ESM log 2300, 2400, 2450, 2500, 2500SC, 2550, 4300, 4350, 4400, 6300, 6350, 6400, 6450
Use the Log2Txt.exe utility to clear the ESM log:
  1. Start your server to the Log2Txt utility.
  2. When you see the ESM Log main menu appear, press 2 on your keyboard to select Clear ESM log.
  3. When the ESM Log main menu reappears, press 5on your keyboard to exit the utility.
1650, 1850, 1800, 2600, 2650, 2800, 4600, 6600, 6650, 7150, 6800, 6850, R900
Use the DRAC or ERA to clear the ESM log:
  1. Type the IP address of the Remote Access Controller (RAC) in the web browser address bar, and then press Enter.
  2. Log in to the RAC.
  4. Click Clear Logs located in the upper-right corner of the page.
1850, 2800, 2850, 6800, 6850
Use the program BMCCFG.exe to clear the ESM logs:
  1. Download and extract the Dell OpenManage Deployment Toolkit here.
  2. Go to x:\Dell\Toolkit\Tools, where x is your primary hard disk drive.
  3. Copy the file BMCCFG.exe to a bootable floppy disk.
  4. Start the server from the bootable floppy disk.
  5. At the command prompt, type bmcc - clearsel, and then press Enter.
    The message "Clearing SEL" will display while the log clears.
1950, 2900, 2950, DP500, DP600, NF500, NF600
Use the BMC/BIOS to clear the ESM log:
  1. To open the BMC menu, press the Control + Ekeys during POST.
  2. From the list, select System Event Log, and then press Enter.
  3. Select Clear System Event Log, and then pressEnter.
=8590&doclang=EN
Jun 09, 2014 | Dell PowerEdge 1800 Server
Error E2011 Memory Config
It sounds like the servers have different memory modes selected :)
Mar 04, 2014 | Dell PowerEdge 2950 (becwfk1_6) Server
Dell Poweredge 2900 I912 SEL FULL
Best is to find a support or systems engineer on http://www.qual.ch if you are in Switzerland and for the UK you can find find a top Dell expert or systems specialist on http://qualifind.co.uk -- I just asked one (from Qualifind) and was informed you just need to install Openmanage and clear the logs from there, no need to down the server.
Mar 26, 2012 | Dell PowerEdge Computers & Internet
Sel full 1912 error
You will get the "Sel Full 1912 error" on your server when the system event log is full and unable to record further events. You must clear the event log before the error will cancel. Boot your system into the BIOS/CMOS, locate the system logs and select clear log, reboot your system. Once the system is back up, I would go into the admin task folder and make sure the logs are clear there as well.
Good Luck.
Please rate my solutions here on FixYa.com
Jan 01, 2012 | Dell PowerEdge 2950 (becwfk1_6) Server
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
C2A2: system event log (sel) full
even tough you did not specify the generation of your server
if this is the complete error message
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS
this is the way to resolve it :
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key.
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup
Aug 18, 2010 | HP ProLiant ML110 Server
Server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
Mar 02, 2009 | HP ProLiant ML150 G3 Server
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
02A2: BMC System Event Log(SEL) Full
In HP prolliant server sets, setup also logs system events. This error is due to that log. Enter setup, trace log and clear all events.
Jan 28, 2009 | HP Compaq ProLiant ML110 G4 Server
Open Questions:
Dell Printer@^+[1]=855-221-4867@&@tech Support Phone Number Tech Support Number Dell Printer Tech Support Number+1(855) 221-4867 time to gayo independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus sare compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight. Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.anning functions. s are compact and lightweight dell printer configuration web tool dell printer default password dell printer document stuck in queue dell printer drivers dell printer drivers for mac dell printer error 004-321 dell printer error 009-340 dell printer error 016-302 dell printer error 016-302 dell printer error 0502 dell printer error 077-900 dell printer error 1203 dell printer error 900.57 dell printer error codes dell printer filter failed dell printer firmware error 900.00 dell printer firmware error 900.57 dell printer fuser error dell printer goes offline dell printer goes offline windows 7 dell printer goes to sleep mode dell printer green flashing light dell printer grinding noise dell printer installation dell printer jam problem dell printer job stuck in queue dell printer keeps calibrating dell printer keeps going offline dell printer keeps initializing dell printer keeps jamming dell printer keeps printing same document dell printer keeps saying downloading application list dell printer keeps saying left cartridge incorrect dell printer keeps saying offline dell printer keeps saying out of paper dell printer keeps saying paper jam dell printer network setup dell printer not communicating with computer dell printer not printing dell printer not printing black ink dell printer not printing color dell printer not recognizing cartridge dell printer not scanning dell printer not working with windows 7 dell printer not working with windows 8 dell printer not working with windows 8.1 dell printer offline dell printer only prints one page dell printer out of paper error dell printer pc life warning dell printer problems dell printer setup wireless dell printer tech support number dell printer there is a problem with the printhead dell printer troubleshooting dell printer will not print dell printer wireless setup dell printer wireless setup utility dell printer won't print dell printer won't print black
Jul 23, 2019 | Dell Computers & Internet
Computers & Internet Logo
351 people viewed this question
Ekse
Clive
Clive
