Try to Restart iPod touch by until Sleep/Wake button until a red slider appears.Next, turn iPod touch on. If iPod touch not responding reset iPod touch, press and hold the Sleep/Wake button and the Home button with same time least 10 seconds, until the Apple logo appears.
If still screen not appear than Recharge iPod touch or try To restore your iPod touch, first make sure you are using the latest version of iTunes(by http://support.apple.com/kb/HT1414). If still not able to solve than take some help with Apple Support Number .
hold power and menu button togerher keep pressed in til it turns on.youl see apple logo still keep pressed.it may need resettimg if that doesnt work may need new battery
If you are talking about resetting after your iPod Touch has hung, you need to press and hold the top and home buttons until the screen goes black. If the iPod Touch displays the "Slide to power off" message, ignore it and continue to hold down both buttons until the screen goes black.
Turn on the iPod Touch by pressing the top and home buttons together again just briefly. It will take a while for the iPod Touch to start up from this type of reset.
If you are looking to restore the iPod Touch to factory defaults, you need to start iTunes on your computer and plug your iPod Touch into your computer with the USB cable that came with it. Click on the iPod Touch from the list on the left side and press the "Restore" button.
Press and hold the "Sleep/Wake" button. This is the main power button on the top left-hand corner of the device.
Press and hold the "Home" button while still holding "Sleep/Wake." The home button is the main button on the front of your iPod touch, indicated by a white square inside of a circular black button.
Hold both buttons until the Apple logo appears on your screen. Resetting can take upwards of 10 seconds. Once the logo appears, your iPod touch reboots by itself.
If that does not work reset the ipod while it is connected to the power. You do this by pressing and holding the sleep/wake button and the home button at the same tme for at least 10 seconds, until either the apple logo or battery symbol appears. If the battery symbol appears, charge the ipod until it is fully charged.
Back up your iPod Touch's data to your computer before the restore to prevent losing data. You'll need to reinstall it after the restore process.
Connect to the internet and install the latest version of iTunes from the Apple website.
Make sure your iPod Touch is connected to your computer.
Pick "iPod Touch" in the Source pane of the iTunes program.
Click on the Summary tab.
Choose "Check for Update."
Select "Restore" and follow the instructions to finish restoring your iPod Touch.
Complete an Advanced Restore
If
following the steps in the previous section did not work, follow these
steps to perform an advanced restore. Turn off the power on the iPod
Touch.
Plug the iPod Touch into your computer.
Power on the iPod Touch.
Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
Release
the "Sleep/Wake" button but continue holding down the "Home" button.
The iPod Touch should reboot, and iTunes will notice the iPod Touch in
recovery mode.
Return to the above section and follow those steps to restore your iPod Touch.
Solution 1) Press Hold/Sleep & hold buttons at same time for 20 seconds, This may fix you problem.
If problem is still alive follow solution 2
Solution 2) Press Hold/Sleep & hold buttons at same time for 10 sec. & then leave only Hold/Sleep button keep home button pressed & connect you ipod to PC, That means you have to bring your ipod in DFU mode (Recovery mode) Check out this video for getting ipod touch in DFU mode http://www.youtube.com/watch?v=bITIiGswjFI . itune must be run on PC. It will ask you for restore. Accept Restore you ipod touch request by itune. Wait for few minutes while ipod being restored.
make sure u hold down home and sleep buttom for more than 11 seconds. After the allple logo shows up, press the home button...i had similiar problems as some of u, and this unfroze/ fixed my issue. Hopefully, it will work for u
