My hoover soft wave maxi 1600 starts fine after 15 seconds run intensive wash button starts flashing and stops all together any help please
SOURCE: my hoover soft wave maxi 1600 that stops on spin
Hi Two things can cause this issue...first when the washer is
unable to drain completely it won't spin, to solve this you can take off the
bottom front panel and then clean the drain pump assembly. If the water is
draining fine then the issue can be with the door lock assembly and should be
replaced. If the door lock sends signal to the control that the door is not
closed the washer won't spin. Hope this helps...please post back for further
assistance. Daniel
