rooCase RC-FIRE-HD7-OG-FL-BK Origami Dual-View Vegan Leather Case Cove Logo
A
Anonymous Posted on Feb 03, 2014
Ordered too many of one item
Tried to order one of each but ended up with 3
Juicer Jar defective with leakage problem.
Question edited for clarity.
Question moved from Computers to Juicers.
3 Duplicates deleted. Refresh the page to see your question.
Just contact Amazon and Return it. Log into your Account, click Orders, Find that Item, click Return, it will ask why? Tell them it leaked and set on fire when you used it for the fist time!
Returns and Refunds - Amazon Customer Service
Amazon.ca https://www.amazon.ca > help > customer > display
Spotlight · Need to Return Something? · Return items using the Online Returns Centre. · Image linking to self service return video · Returns Items You Ordered.
Return Items You Ordered
Return Items You Ordered · To display your recent orders go to ...
Returns
Returns. If you need to return or replace an item, visit Your ...
Amazon Refund Timelines
We typically process returns within two weeks after the carrier ...
Track Your Return
Track Your Return · Go to Your Orders. · Select View Return ...
Dec 12, 2023 • Juicers
What is meant by systematic and objective approach
the words are the clue to the answer
systematic approach is to do every thing systematically
step one on to step 2 on to set 3 etc
example is -- know what is needed , find supplier, place order , pay for the order, receive the order , check the order, place on display, sell , receive payment, bank funds , reorder item
objective approach is to decide on what is required and planning to reach that objective
example -- need goods for sale, how to get the goods , how to pay for the goods , how to improve on the process
IN business it will work like this
example a CEO of a company wants to reduce the injury rate of the employees
he sets a policy that has KPI's and bench marks to achieve the end result of reduced injuries( objective )
The managers have to implement that policy and have to plan each step( systematic) of the operation to eliminate risks that cause the injuries and in the end achieves the objective of the CEO
Where from can i get complete bobbin case the part was missing in my old Janome machine
Have you tried a Janome dealer? Sometimes they carry parts for older machines or maybe they can order it.
I ordered 3 items by mistake. How do I cancel 2?
Orders usually go into a shopping cart. Sometimes there is only a chance to remove items or modify quantities after arriving at the checkout.
Often it is simpler to use the wish list facility instead of putting stuff straight into the shopping cart.
If you can't modify your order then either simply don't complete by paying for it or cancel it and start again.
Customer services might be able to help further.
If all else fails you should be able to return unwanted goods, though as you "ordered in error" it is likely to cost you postage.
Order for combined books duplicated as these books I ordered separately. Would like to cancel and get further in series
Cancel Items or Orders
1)Go to your orders
    2)Click cancel items
    3)Select check box next to each item you want to remove from the order.
    4)Click cancel checked items when finished
Return centre
if the item is out of stock you can cancel the order
you cannot return what cannot be delivered
contact the supplier by phone and demand a refund of the money for a non-deliverable item
CANNOT SETTLE PARTIAL PAYMENT ORDER
Please contact the vendor or company you are transacting with as for sure they have problems on their website.
Hi, I called HP customer centre in Singapore to help me for my printer as I don't have the wires to connect my printer to my computer. They advise me to order and I did. Now I want to cancel my order. My...
We cannot cancel your order. Only HP can do that. You can attempt to cancel it by going to their website.
There are several contact options here http://welcome.hp.com/country/us/en/contact_us.html
Have you tried to cancel using the same number that you ordered from?
Orders are usually filled and on their way very quickly. You may not be able to cancel, and may receive the order very soon. There will be instructions and possibly even a mailing label for returning the item and receiving credit for it. You will have to package the item (you may be able to use the same package the item came in if it is in good shape.) and pay for return postage however.
I have a whirlpool gold over the top range microwave gh7155xkb. it runs fine but does not cook.
Microwave problems as you describe can be the result of a failure of any of the following:
1) Internal fuse
2) Failed diode
3) Failed rectifier
4) Failed magnetron
5) Failed transformer
Any one of these components could be bad. Do not attempt repair yourself unless you are comfortable with working with high voltage electronics. I've listed the failures in order of cost, with 4 and 5 being interchangeable in terms of cost. The fuse is the only item which can be checked. The rest are replaced by trial and error, with the first three items being tried at the same time. All items can be ordered from various places on the internet.
15helpful
2answers
Daewoo Lanos Ignition Wire Order
spark wire order of daewoo lanos is 1423 with you facing the engine; spark 1 is on th extreme left then 2,3,4 ..insert them as 1 (extreme left) is the highest to be plugged in, under which insert 4 then 2 then 3 at the bottom, hope it helps
Top rooCase Water Sport Experts
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a rooCase Water Sport Expert? Answer questions, earn points and help others
