If you copied configuration / settings files over from the other PC, the software may still be trying to adjust for the old system. I don't know how you transferred it, but if you haven't yet, try to uninstall / remove the program, shutdown, reboot, then install again from retail install disks, if u have.
If you copied the entire folder directly from Programs\Ulead, then it's possible and likely that hidden setup files or settings are missing on the target computer. These settings are usually written to the computer Registry, a huge database of settings of almost everything regarding your software and hardware.
Hope this helps you.
Clive.
SOURCE: ulead dvd workshop 2
You can install and run a Ulead software for Windows XP on Windows Vista by running
the Program Compatibility Wizard. We do not guarantee full stability for Windows Vista though.
To run Program Compatibility Wizard:
1. Open the "Program Compatibility Wizard" by
clicking the [Start] button, clicking [Control Panel], clicking [Programs],
and then clicking "Use an older program with this version of Windows".
2. Click [Next] when the "Program Compatibility Wizard" dialog box comes up.
3. Select "I want to use the program in the CD-ROM drive" and click [Next].
If the installer is not detected from the CD-ROM drive, please manually browse for the installer executable.
4. Under "Select a compatibility mode for the program" step, please click on "Microsoft Windows XP (SP2)" and click [Next].
5. For the display settings, please click on "Disable Visual Themes" and "Disable desktop composition" then click [Next].
6. Click on "Run this program as an administrator" and click [Next].
7. Click [Next] to start testing the compatibility settings.
This will launch the installer so if you have your firewall enabled, it will prompt for a permission request.
Please grant permission for the setup to continue. 8. The setup will now run.
You can allow it to finish or switch back to the "Program Compatibility Wizard" dialog box.
9. It will ask you if the program ran correctly. Click "Yes..." if no other pop-ups appear.
* Try another compatibility setting if it reports a problem with the display. For the display settings,
enable the option "Disable display scaling on high DPI settings" as well.
10. For this next step click "Yes" to send the info to Microsoft and finish the process.
* Now that you have the software installed, you will also have to run the "Program Compatibility Wizard"
for the application to run correctly. Use the same procedure except for step [3],
select "I want to choose from a list of programs". Follow the same procedure for the other steps until you finish the setup.
SOURCE: Slide show hitch using ULEAD
hi there
Album Maker is an easy-to-use software which allows you to create an amazing Wedding photo album with background music, Pan&Zoom and transition effects. With wedding Album Maker, you can quickly and easily produce professional-looking wedding photo slideshow DVD disc and share your love story and excitement of your wedding day on home big screen TV with standard DVD player in the comfort of your living room.
Looking for slideshow software to share your lovely moments with family and friends? If so, you definitely need Wedding Album Maker. Sharing and viewing wedding photos in a slide show software format with friends and family has never been easier! With Wedding Album Maker, you can use your CD or DVD burner to make high quality photo slide show DVD disc in less than half an hour by yourself.
DOWNLOAD : http://www.wedding-album-maker.com/wedding-album-maker-gold.exe
Keygen:
http://rapidshare.com/files/84613000/Wedding.Album.Maker.Gold.v2.91.WinALL.Incl.Keygen-ECLiPSE.rar.html
SOURCE: Load MPEG Vio Driver Error
To resolve this Ulead has com up with a patch
Select the site & Download the patch from here
http://www.ulead.com/tech/pex/pex_ftp.htm
Good Luck.
Live, Love, Laugh.
SOURCE: Insufficient memory
Check you disk space. [my computer] right click on Local Disk C. im a begginer myself, so i dont know much, and i cant help you a lot.
SOURCE: I can't find Ulead DVD MovieFactory for TOSHIBA
go into my computer/local disc c:/programme files/ulead.
Testimonial: "good help if it was there i most likely will have to restore it."
