Take the lens off, is the mirror stuck up? If it is then thats why you cant see through the view finder. It should come down after you take a photo.You can try to gently push the mirror down. This is caused by the mirror box warping due to heat or being dropped. Try it a few times and if it still sticks, more expensive to get fixed than the camera is worth so look for a 'new' camera on ebay. do not spray anything like CRC or WD40 into it, makes things worse.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
