P - Pink LB - Light Blue V - Violet GR - Grey LG - Light Green BR - Brown L - Blue Y - Yellow O - Orange G - Green R - Red W - White B - Black Some wires will be allocated 2 colors ie B/W. This is a color with a different color line running along its length. The first denotes the main color (Black in our example) and the second denotes the tracer line (White in our example)
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey... Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White... Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k.
all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv
now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Dont have a diagram but if you wanna know the colours they are
Red - Accessory Power
Yellow - Battery+
Black - Ground/Chassis
Orange/White - Illumination
Blue - Power Antenna
Blue/White - Amp remote wire
Brown - Celluar phone mute lead
Speakers:
Front Right - +Grey -Grey/Black
Frount Left - +White -White/Black
Rear Right - +Purple -Purple/Black
Rear Left - +Green -Green/Black
red -Acc power yellow -12 memory power black -ground blue -amplifier remote blue/white -power antenna SPEAKERS white left front + white/black left front - grey right front + grey/black right front - green left rear + green/black left rear purple right rear + purple/black right rear -
