I'm working on my buddies PLV-Z1 and he just replaced the lamp, but the ready light does not light and the lamp indicator is flashing... any ideas... looking for a service manual also
The fan may be out that keeps the bulb cool. The shutdown is to protect the lamp from overheating. Do you have any flashing indicator lights on the projector after turning it on?
2 different brands and models listed here--for the Samsung inspect to see if color wheel is intact and not shattered---have to remove the lamp to see it.
what about the Projector Condition leds: POWER, WARNING and LAMP REPLACE? How are they lit? For good measure you should also clean the air filter (the projector might not be getting enough air to cool the lamp)
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
we had this problem and it ended up being that one of the fans under the lens assembly was not working, causing the system to shut down when it tested it at startup
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be gone and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Ah! thanks... the manual can go to - [email protected]
[email protected]
thanks...
where shall i send manual to?
