Hi, Yeah it seems this happens a lot with treadmills. This should still be under warranty if you purchased it 3 months ago. If you got it used, buyer beware, the old saying. I'm sorry to say but it sounds like the motor starts, at a slow pace, then gets hot and shuts down. It doesn't sound like a controller on the board. When they go out, they go right out. Is there a way you can test it for voltage output? that would be my first check. Alligator clip it and run the motor while checking the output. Check the manual for the voltage output. Good luck.
DEAR
IF IT STOP AFTER 6 OR 8 SECOND YOUR SPEED SENSOR IS NOT FIX AND ITS OUT OF SERVICE YOU MUST FIX IT SIMPLY AND YOUR TREADMILL WORK AS WELL
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
SOURCE: I have a LifeSpan TR1000-TV
The error ERR-1.This error is caused due to motor board getting faulty.And due to motor board getting weak this makes the belt overheated because belt does not get enough power to spin as per the required speed set on the display to spin.
As per the Lifespan treadmill manual it says that lubing the belt helps.But actually this is a temporary solution.Because when you lube the belt it gets frequent movement to spin.It actually gets dried up due to overheat.So lubing makes it spin freely.But it again gets dried up after it gets overheated again.This cycle continues again n again.And at last internal motor coils and connections gets overheated and starts giving burning smell from both the belt and motor.
The exact solution for this problem is two replacement.The motor board including motor and the belt has to be replaced.
Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation.
