I've updated my HP 6720s CPU. Previously it had Intel Celeron M CPU 530 @1.73 GHz and now I replaced it by Intel Core 2 Duo Processor T5870 (2.0-GHz, 800-MHz FSB, 2-MB L2 cache). The problem that I have now is that when I power up my laptop after Windows logo all I have got is blurry image on display and some random dots. Can't see a thing! To bypass this first I have go to Safe mode, then restart it and then it's ok. If I skip Safe mode part all I've got is described blur on display. Please help, what should I do? Do I need to install something? I already tried to update Bios, reinstaling Windows and it didn't help. The problem is still the same,no matter if I run laptop on battery or via power supply. Please advise. Thank you in advance! Here are specs: Motherboard: HP model: 30D8 KBC Version 83.0C Chipset: Intel GL960 Rev. C0 Southbridge: Intel 82801HBM (ICH8-ME) Rev. B1 Previous processor: Intel (R) Celeron (R) M CPU 530 @1.73 GHz Current processor: Intel Core 2 Duo Processor T5870 2.0-GHz
Hey;
Start your computer and right after the hp logo, keep pressing the F8 button until you see a large list of options.
Select
"USE LAST GOOD KNOWN CONFIGURATION"
and press enter. Let windows load and it should work just fine.
Testimonial: "Hello! Thank you for you answer. Unfortunately this didn't help. The problem remains. I've tried everything that I could think of, updating BIOS, re-installing Windows, updating drivers and nothing.."
Hey;
Sorry, have you considered doing a total system restore? To do so, at startup, keep pressing F11 and system restore should start, just fallow the steps.
Hey! Thanks for helping me to solve this problem. I'll try this as soon as I get home. Tell me, if I do so will I lose all data on laptop? So I could first back up all my files to external HD.
@ privatetearms _ thanks for help, unfortunately this didn't help. Can some one recommend OC programs that are user friendly, I'll try to down-clock CPU just a bit.
SOURCE: Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
SOURCE: Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Testimonial: "Thanks for the quick response. I was afraid that might be the answer but I appreciate the confirmation."
SOURCE: I need to replace the Intel Core 2 Duo T7300 processor
you can check it up here for only $23.18
http://www.amazon.com/Intel-T7300-2-00Ghz-Fsb800Mhz-Fcpga6/dp/B00180IOLS
