When the phones rings the phones will ring then says no connection to base then ring again. It does that the entire time it rings. It makes it hard to answer. What could cause this problem?
Remove the telephone from it's base; then remove the battery cover; disconnect the battery.
With the battery disconnected, press the power button on the telephone to fully discharge it.
Wait 2 minutes to be certain the telephone is fully discharged, then reconnect the battery and replace it on the base.
This will get you to the point that you can go out and purchase a replacement battery for these panasonic cordless telephones.
SOURCE: How do I retrieve messages on the Panasonic KX-T7030 phone?
By default, three options are enabled:
option #1: leave a message
options #5: call the operator
option #6: return to top menu
Here are some other features you may need
SOURCE: KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
SOURCE: my Panasonic KX-TG2361JXB cordless phone answering
I NEED MASTER PASSWORD OD CORDLES PANASONIC..KX-TG2361JXB
