Computers & Internet Logo
A
Anonymous Posted on Feb 03, 2014
Ipad 2 is activation locked via iOS7. - Jabra Computers & Internet
3 Related Answers
Andy98NZ
  • 11 Answers
  • Posted on Oct 20, 2013
SOURCE: since installing IOS7 on my Ipad it loses its
Ios 7 requires more power and a higher processing speed this is one of a small number of negatives to ios 7. :(
lycanloki
lycanloki
  • 272 Answers
  • Posted on Oct 21, 2013
SOURCE: Can't play itv player on ipad after downloading
  1. Make sure you have the lastest verison of the app downloaded from the appstore.
  2. Delete the app, and re-download it.
  3. Reset ipad to factory.
  4. Re-attempted step 2.
Bryan Smith
  • 373 Answers
  • Posted on Dec 04, 2014
SOURCE: ipad ver 4.ios7, how can I remove previous owner from ipad? ive removed pasword and I cannot contact last owner
Go into setting and then "Reset". Then choose to reset all and delete all content from previous owner.
To activate my ipad
It's a common issue. You can try the below solutions.
Solution 1: Retry after Some Time
Solution 2: Restart your Device
Solution 3: Network Issue
Solution 4: Lock/ Unlock SIM Status
Solution 5: Activate Via iTunes
Solution 6: Restore iPhone to Factory Settings before Activation
For more details, check: How to Fix "iPhone Activation Server Cannot Be Reached"
2answers
How do i bypass the apple id activation on my iphone 6?
iCloud Locked iPhone 6 How to bypass iCloud Lock on iPhone 6
So, in this post, I would like to show you 4 solution about iPhone activation bypass
Solution 1. Remove iCloud Activation Lock from your iPhone 6 with Unlock Tool
Solution 2. Bypass iCloud Activation Lock Software via iCL0udin
Solution 3. Bypass iCloud Lock via Apple Setting
Solution 4. Bypass iCloud activation online with iCloud Lock Removal Service
Sep 19, 2016 • iPhone Apps
How to down load free iOS 7 tommymipod?
This all depends on which iPod you have ....
IOS7 is only compatible with:
  • iPhone 4
  • iPhone 4S
  • iPhone 5
  • iPad 2
  • 3rd generation iPad with Retina
  • 4th generation iPad with Retina
  • iPad Mini
  • 5th generation iPod touch
  • So if you do not have one of these you cannot install IOS7.
  • 0helpful
    1helpful
    2answers
    How to unlock ipad2 puk code
    Your iPad 2 must have 3G, with a sim card. For the sim you need the pin and after 3 misses you need the puk. The puk is on the letter or card that came with the original sim card. On that letter is the pin and puk. sometimes you have to scratch away the metal layer.
    If you want to unlock an iPad, with the lock code on, and forgot your pass code you have to enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPad, invoice, Prove of your identity (Passport) to the Apple store and hope they will unlock your iPad. With iOS7 Apple mede a very good security system. And while setting up the iPad and the security, you are warned several times what to do t make sure you and only you could enter the system.
    Be aware if Apple does reset your iPad, all data now on the iPad will be lost.
    Can't play itv player on ipad after downloading ios7
    How do you delete ios7
    Once you have updated your iPad you cannot roll back the update. This is the case with iOS7 and downgrading is not supported.
    Hope that helps!
    1helpful
    How to remove ios7
    Once you have updated your iPad to iOS7 you cannot remove it. Downgrading is not supported by Apple.
    Hope that helps!
    I don't know how to update to iOS7 can someone tell me?
    You can update your iPad to iOS7 as long as it is and iPad 2 model or later. The update can be performed wirelessly or by connecting the iPad to a computer using iTunes.
    For step-by-step directions for both methods, check out the Apple website: http://support.apple.com/kb/ht4623
    Hope that helps!
    My ipad is locked after downloading iOS7 Asks for 4_figure code which I do not have and did not require for iOS6 Please help
    You may have added a 4-digit code during the set up phase after iOS7 installed. I noticed apple added this as a step in the new updates.
    If you cannot figure out your code, plug the device into your computer, open iTunes, and do a factory reset. Hopefully you created a backup before installing iOS7, but if not make sure to create a back up before doing the factory restore.
    After restoring, just place the backup back on the device.
    Hope that helps!
    Top Jabra Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Jabra Computer and Internet Expert? Answer questions, earn points and help others
