True T49F Freezer Logo
H
Hans Huepers Posted on Feb 03, 2014
Will not cool all the way
Why is my t49-f not cooling?
Samsung refrigerator wont cool down
JUST ROTATE YOUR THERMOSTAT TO THE MAXIMUM AND WATCH IF STARTS COOLING THEN ADJUST THE THERMOSTAT TO YOUR REQUIRED LEVEL LATER ON. iN CASE IT DOES NOT START COOLING CHECK THE COMPRESSOR WHETHER IT IS WORKING, IN CASE YES THEN THERE IS NO GAS IN IT
Ice build up in bottom of freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Compressor vibrates and unit only cools to 20 degrees. tech says it "may" be compressor pressure valve ($1800.00) but no warranty. I cant find any such part listed for True T49-F commercial...
Okay first True uses capillary tube not an expansion valve.
You say the compressor vibrates not cooling ?
If the valves of the compressor are bad, he may mean
internal valves but usually pressures would not be good.
Give a little more detail please.
Kelvinator no frost KBNT23AS back plate in the freezing compartment is icing up but the ice trays are not freezing. The lower compartment is not getting cool enough.
heatman101
Freezer ok fridge not cold enough
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
My frost free freezer is frosting up. what can I do
heatman101
Freezer works ,fridge does not?
heatman101
Dec 12, 2010 • Freezers
It sounds like running but its not cooling
Two reasons for not cooling 1 The gas has leaked out. You have to request the technician to check the same. 2 Thermostat switch/dial is not put on cool. Put it on the max cool or the highest number if numbered
Jan 27, 2010 • Freezers
3helpful
Samsung cool n cool freezer & refrigerator does not cool
samsung refrigerator won't cool how do we fix it?
Apr 14, 2009 • Freezers
Top True Freezers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a True Freezer Expert? Answer questions, earn points and help others
