Tplink. WR841n. V8.4 flash. firmware
SOURCE: Fast Flashing Light - no Internet connection
Well, i also had a wrt54g router.Generally that type of router is only for a networkwith one, two max wireless items. When the led light is flashing very fast, it means it is working very hard. You may need to get a stronger router such as the wrt300n which can handle up to about 10 items. By the way, netgear routers are generally stronger and longer lasting than linksys.
SOURCE: If I connect TP-LINK TL-WR1043ND
If your OS is Windows there is a good tutorial at -> Working with Widows Wireless Networks
That can help you out to configure your wireless networks.
If you need more help post back!
Thumbs and testimonial are welcome!
SOURCE: TP-LINK TPLink TDW8950ND 150Mbps Wireless
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers can communicatewith your wireless router.
SOURCE: TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
SOURCE: can't connect to my router
try reset your router , and look at the status of lamps , then tell me that
Testimonial: "c'mon , i tried to reset router, but nothing happen :( how i can reset router?"
