I got an error message telling me to check the printer and push the "ok" button. I tried that but nothing happened. I tried printing a page and got an error message on my computer telling me to press the "ok" button again. Then the machine just shut down completely and won't start up now.
Make certain you have the current updated drivers for the printer. Check to see if the printer is recognized as one of the devices active and available. If its wireless, be certain the communication is both ways. Do a printer test of the Wireless transmission phase. If you connect directly by Cat5/6 cable with Ethernet, check drivers. Check cables. Check for a positive connection on both ports, Computer and Printer. Make certain the printer listed is the Main Printer when you do a setup.
SOURCE: Check Ink U130 5BK
Hold down the Stop/Reset button for 5 seconds or so - should start working now - although this stops the low ink warnings from then on
SOURCE: error 306 is happening each time i try to print document.
I reloaded the printer driver and it worked again.
SOURCE: mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
SOURCE: Canon MP810-CD-R Tray loading-printing problem
I am trying to print on DVD with Canon MP810 but the image won't line up - seems to be taking the tray too far in and printing some of the image on the F tray! Help.... it's driving me nuts
SOURCE: My MP780 is displaying wrong cartridge, I tried to
I had the same problem on my pixma mp780. I cleaned the printer head. it worked for about a year, but then i had to replace the printer head. after you clean or replace it reboot it.
