Konica Minolta bizhub 350 All-In-One Laser Printer Logo
A
Anonymous Posted on Feb 03, 2014
Stop 00 stop 01 - Konica Minolta bizhub 350 All-In-One Laser Printer
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jan 24, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913153
Points
11959
Yes what about it???????????????????????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2004 chevy impala brake light isses switch has been replaced and so have fuses and bulbs still no lights
Do you know how to test using a DVOM - digital volt ohm meter ? Is there B+ voltage going into the brake light switch ? An coming out when the brake pedal is pressed ? What fuse's ? There is only one fuse for the brake lights !
The BRAKE SW fuse in the RH I/P fuse block supplies battery positive voltage to the normally-open stop lamp switch. When you press the brake pedal the switch contacts close and battery positive voltage is supplied to the left and right stop lamp assemblies and to the center high mounted stop lamp (CHMSL). The left and right stop lamp along with the CHMSL are grounded at G302.
Do you know about the right insturment panel fuse box ?
Stop Lamps Inoperative
Step
Action
Yes
No
Schematic Reference: Exterior Lights Schematics
Did you perform the Lighting System Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Lighting Systems
Press the brake pedal.
Do all of the stop lamps illuminate?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Are all the stop lamps inoperative?
YES - Go to Step 4
NO - Go to Step 7
Inspect the BRK SW fuse.
Is the fuse open?
YES - Go to Step 14
NO - Go to Step 5
5
Disconnect the stop lamp switch.
Using a test lamp connected to ground, probe the battery supply voltage circuit of the stop lamp switch connector.
Does the test lamp illuminate?
YES - Go to Step 6
NO - Go to Step 13
6
Install a fused jumper between the battery supply voltage circuit and the stop lamp switch signal circuit of the stop lamp switch connector.
Do the stop lamps illuminate?
YES - Go to Step 12
NO - Go to Step 17
7
Determine if the center high mounted stop lamp is inoperative or the stop/turn lamps are inoperative.
Are the stop/turn lamps inoperative?
YES - Go to Step 8
NO - Go to Step 9
8
Do the turn lamps operate normally?
YES - Go to Step 17
NO - Go to Turn Signal Lamps and/or Indicators Inoperative
9
Disconnect the center high mounted stop lamp.
Using a test lamp connected to ground, probe the stop lamp switch signal circuit of the center high mounted stop lamp at the harness connector.
YES - Go to Step 10
NO - Go to Step 15
10
Using a test lamp, probe between the stop lamp switch signal circuit and the ground circuit of the center high mounted stop lamp with a test lamp.
Go to Step 11
Go to Step 16
11
Inspect for poor connections at the harness connector of the center high mounted stop lamp. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 20
Go to Step 19
12
Inspect for poor connections at the harness connector of the stop lamp switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 20
Go to Step 18
13
Repair a open or high resistance in the battery supply voltage circuit of the stop lamp switch. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 20
14
Repair a short to ground in one of the following circuits:
• The battery supply voltage circuit of the stop lamp switch
• The stop lamp switch signal circuit of the stop lamp switch
Go to Step 20
15
Repair a open or high resistance in the stop lamp switch signal circuit of the center high mounted stop lamp. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
16
Repair an open or high resistance in the ground circuit of the center high mounted stop lamp. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
17
Repair an open or high resistance in the stop lamp switch signal circuit of the stop lamp switch. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
18
Verify the stop lamp switch adjustment. Refer to Stop Lamp Switch Adjustment . If OK, replace the stop lamp switch. Refer to Stop Lamp Switch Replacement .
Go to Step 20
19
Replace the center high mounted stop lamps. Refer to High Mount Stop Lamp Replacement .
Go to Step 20
20
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Why does it keep stopping with lights flashing when filling bobbin?
Singer 7422 keeps stopping with lights flashing when filling ...
www.fixya.com/support/t26006759-singer_7422_keeps_stopping_lights
4 hours ago - Singer 7422 keeps stopping with lights flashing when filling bobbin Machine stops ... Machine stops and red lights flash when loading bobbink.
Why has launcher stopped working?
launcher stopped working Tablets & eReaders Questions ...
www.fixya.com > Forum > Tags > launcher stopped working
Tablets & eReaders launcher stopped working questions and answers. Ask your ... is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to ...
Unfortunately, Launcher has stopped - Android Forums at ...
forums.androidcentral.com/.../357082-unfortunately-launcher-has-stopp...
Jan 26, 2014 - 22 posts - ‎17 authors
... up my tablet I get a message "Unfortunately, Launcher has stopped" ... or Korean and then help me to solve the launcher stop working error ...
[Q] Unfortunately Launcher has stopped and o... ' Asus Transformer ...
forum.xda-developers.com/showthread.php?t=2069137
Dec 27, 2012 - 9 posts - ‎2 authors
Third-Generation Kindle Fire HD Gets Bootloader Unlock Tool ... Currently stuck with a "Unfortunately, Launcher has stopped" on my ... It has been working very well since then, but in the last days, ... I do have a build.prop editor installed on my tablet, but since I can't launch app, I don't know how to do it.
Error 'Launcher Has Stopped Working' ' Android Tablet Forum
How do i go to no stop mode on bizhub c450/
Utility-Meter count-Check details-Stop 00-Stop 01- Stop 0 C select IU life stop setting-NO STOP
Skytec Astra alarm system just quit working unexpectedly
STOP STOP STOP STOP STOP STOP OK OK OK OK OK OK OK OK OK OK OK OK
How to reset the counters of the dev unit of konica minolta c360
The developer unit has been reset automattically,after change the old unit another new.You can change the developer unit life STOP after 45000 copies or NOT STOP more 400000 copies.To change the unit life press:
Utility - Meter count - Check details - Stop - 0 - 0 - Stop - 0 - 1 -Stop - 0 - C - select IU life stop setting touch NO STOP.
How do I set the stops? with the valve close the white moval stop is against the the fixed stop - where should the black movable stop be when the valve is closed> Also what is the function of the stop -...
the white is a temp limiter stop...and the black is a personal temp setting...the white at max temp should be up to the brass stop and the black is adjustable to personal adjustments...good luck
4helpful
Shows ER07 ER09 ER 01 Scrolls through 01 etc. and eventually shows ER09 SAGEM Model DVR 6200T/6400T
I had a very similar problem. On initially starting up it showed Pb03 then would cycle between er07 er09, er01 and counting up 00,01 up to 19 or so.
Nothing I did fixed it including turning it off for a long period and back on without the aerial.
Eventually I fixed it by pulling out the power cable while it was counting up and then on powering back up it started to initialise correctly. No idea what the problem was and why this fixed it but it might be worth a go. It didn't involve losing any recordings.
11answers
Need todays starview codes
i want a code for my eurovox box please i live in preston area
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
