Jet 3 Ultra Power Chair Logo
Posted on Jun 05, 2009
Jet 3 Ultra power wheelchair dripping grease on floor
My father's power chair is dripping dark grease from the back of the drive wheel.
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jun 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
2246
Points
11
Your motor needs to be replaced any questions call me at (866) 598-6230
What is the fix for Pride power chair code 3101 bridge voltage fault?
The fix for this fault is to replace the chip in the VSI controller. This happens when you consistently drive the power chair with weak or low voltage batteries.
Oil leakage in pronto power wheelchair
if the leak is by 1 of the wheels it could be the seal at the drive out put ,if you can't find a seal it could be gotten from a bearing supplier ,it would need to be matched
Power chair
that is a tricky one definitely a loose connection need to find it by trial and error wiggle wires while driving till it stops. best to call for service from a qualified tech
2helpful
Clanklng in left drive wheel
if you block your chair up in the air so your wheel is off the floor you can check for a few things. First roll the wheel around and see if its rubbing. next see if the barrings are out if they are the wheel will woble. next see if the bolt in the center is tight. if you catch this in time it wont cost alot if any money
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
2answers
Where can I get the manual for Jet 3 motorized power wheelchair
acampbel I went to pride website and could only find the manual for the Jet 3 ultra. I don't know if that manual can help you but goto pridemobility.com and select Jazzy chairs, scroll down until you see the picture for the Jet 3 Ultra click on the picture and you can download the manual from that page. Hope this helps you
2helpful
I need a replacement manual for my wheel chair by scooter model jet 3
Hi. Go to the pride australia web site. You might be able to download a manual. If not then just google pride jet 3 and see what you get. Good luck. Neil.
9helpful
3answers
Lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Top Jet Health & Beauty Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
