Samsung S85 Digital Camera Logo
A
Anonymous Posted on Feb 03, 2014
Samsung s85 factory reset - Samsung S85 Digital Camera
Samsung S85 lens cover only closes halfway
Sounds like the lens cover will have got knocked off the guide rails, not much you can do, try blowing it with some compressed air incase there is any debris/grit stuck in there
Hello i have a samsung camera model S85 and when i try to turn it on it does 3 beeps and doesnt even turn on.
Assuming you've tried the obvious test of using new batteries, it's unfortunately likely to be the infamous "lens error". This is such a common problem that someone has written a blog just addressing this one error. You can read it here - it describes it far more completely than I ever could!
Also, check this post.
I need a manual for my Samsung camera Model S85. Can you send it to me? E-mail: [email protected] Thanks!
GO TO THE LINK AND DOWNLOAD IT !!!http://www.retrevo.com/support/Samsung-S85-Digital-Cameras-manual/id/3256ag704/t/2/
1helpful
How do you print from a samsung s85 camera?
Dear friend,
Follow the step.
1. 1st install a printer on your pc.
2. install your camera .
3. Make default your printer for your camera.
4. on your printer, then c$onnect your camera with detacable and then on your camera.
5. go and print your photo from camera.
6. print will start.
THx
2helpful
Samsung S85 problem
I have had similar symptoms that seem to be due to battery power.
Using and OHM meter I find that the Samsung S85 eats batteries. If the charge drops to 1.4 something volts from a 1.5+ volt battery, the camera does not function properly.
The camera is nice an compact ... but I need to carry the same volume in batteries to make sure I can use it.
2answers
Lost software cd for samsung camera s85
Go to their download center.
http://www.samsung.com/us/support/download/supportDownMain.do
enter model number and follow directions.
Happy downloading!
Samsung S85 camera , USB Error?
Check the USB port on the camera for signs of debris or corrosion. There also is a USB driver chip on the main system board that could go out, but that is pretty rare. Maybe your pet chewed on your USB cord. Double check.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
