Question about SanDisk Sansa c240 MP3 Player
Sansa c240 and a 4 GB Micro SD HC card.
Right, well I have a Sansa c240 and a 4 GB Micro SD HC card, I'm not very tech savvy but I don't understand why it wont work. When I plug the card in it takes a while longer for my mp3 to get all loaded and started, but I find none of the music that's on the card can be found on the mp3 player.
This card works in my LG Rumour perfectly fine but eh. I've looked for some answers online and one site mentions something about installing some sort of firmware... but I haven't even the foggiest what that means.
  • 30 Answers
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Posted on Jun 06, 2009
Sansa firmware version 1 of sansa c240 can support only micro sd cards of maximum 2gb,if you want to use micro sd hc cards(4gb &above) you have to install ROCKBOX firmware,it claims to support micro sd hc cards upto 32gb though maximum available micro sd hc card at present is 16gb,for more information on how to install rockbox firmware on sansa c200 series go to ROCKBOX website- www.rockbox.org
Posted on Dec 25, 2009
  • Matthew Slattery
    Matthew Slattery Oct 15, 2014
    C240 does not claim to hold 32 GB. I still have the book and all and the unit. It states 2GB max Even Sandisk will tell you only 2GB. I wanted to double check with them just recently since misplaced the booklet.
I'm pretty sure because this model is old, it is only compatible with up to 2GB standard microSD cards. HC (high capacity) ones or other SD cards with new technology won't work.
of course I can't even get my standard 2 GB one to sync in windows media, or appear in winamp, so i'm struggling as well.
Posted on Jun 09, 2009
    Novelist:
    Scholar:
  • 99 Answers
Ah yes I have dealt with this even after the last firmware update. I contacted them and they told me the max should not exceed 2 GB it will not recognize anything higher. It takes awhile to load because it is gathering info from the card and checking that it is compatible. Since you are using 4GB it is not being recognized. 1 option that might help is erase the card (re-format) put it in the Sansa player then connect to your pc. Open computer (my computer) or if it automatically opens check the storage if It is recognized it will properly display external storage and the space.
Or you can open windows media player open syn pane and browse to see if it shows up there. If it does not show then once again the unit is not recognizing it.
Posted on Oct 15, 2014
SOURCE:
My 128 gb sd card is no longer working after trying to make it adoptable storage in my s7, my phone or computer wont recognize it anymore pls help
64GB and higher capacities need to be formatted with exFAT.
Some help: https://www.youtube.com/watch?v=JA9fp863d-o
A tool for formatting SD and micro SD cards is SD-formatter:
https://www.sdcard.org/downloads/formatter_4/
Oct 23, 2016 | Electronics - Others
FORMATEAR MICRO SD HC 8GB
Depending on your laptop, 8 GB SD cards may not work. That said, insert the SD card, open Computer, right click on the SD Card icon, format.
Dec 13, 2012 | Toshiba Computers & Internet
Hi i got a 32 gb sansa fuze memory card.. like 2 weeks ago. from buy.com and well today i got my sansa fuze white player. the memory card will not fit into the player. I would like to get a memory card...
From your description, you seem to have bought a regular SDHC (secure digital high-capacity) card. A Sansa Fuze can only accept micro SD or micro SDHC cards. For buying a new card, I would suggest this card from newegg.com. As for other things you mentioned: No, the card you bought is not meant for cameras only, the only reason your device uses micro SD/SDHC cards is because it is a smaller device. The 4 on your card signifies that it is class 4 which is the card's speed classification.
Jul 12, 2011 | SanDisk 1GB microSD Memory Card
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e270 MP3 Player
Installing Micro SD card to Sansa e260R
The Sansa e260 Rhapsody (e200R series) supports:
1. micro SD cards ( not the HC type )
2. micro SD cards up to 2 GB of memory capacity
See next site:
http://kb.sandisk.com/app/answers/detail/a_id/200/related/1
Jan 10, 2010 | SanDisk 4GB microSD High Capacity Memory...
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Jun 29, 2009 | SanDisk Sansa e260 MP3 Player
Not recognizing the memory card
if the micro sd is HC the sansa will not read it because it does not have the right firmware and connection to read an 8 GIG if you want that get a sansa view
Nov 13, 2008 | SanDisk Sansa E280 MP3 Player
My phone NOKIA 6300 could not find micro SD card. please what do i do?
If it is a 4GB micro SD card it won't work, a nokia 6300 doesn't accept HC (high Capacity) micro SD cards. Maximum you can use is a 2 GB micro SD card.
Don't forget to rate, thks
Oct 28, 2008 | Samsung SGH-D900 Cellular Phone
Memory stick not identified.
The memory stick probably is not the right type. The Sansa only takes SD Micro chips. However, IIRC Micro only goes up to 2GB. So, if you have a 4GB chip is must be a SD HC (High Capacity). Unfortunately, these do not work in the Sansa.
Feb 28, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa c240 MP3 Player Logo
1,730 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
