Learn how to completely uninstall iTunes, QuickTime, and other essential software components from your Windows XP PC.
How ToFor Windows Vista or Windows 7, see this
article.
Expand All Sections |
Collapse All Sections In
some rare instances, it may be necessary to remove all traces of
iTunes, QuickTime, and related software components from your computer
before reinstalling iTunes.
Use the Control Panel to uninstall iTunes and related software components in the following order:
- iTunes
- QuickTime
- Apple Software Update
- Apple Mobile Device Support
- Bonjour
- Apple Application Support (iTunes 9 or later)
Important: You
may see various alert messages if you uninstall these applications in a
different order or only uninstall certain components.
For detailed steps on removing and reinstalling iTunes and related components on Windows XP, refer to the following steps:
Removing iTunes
Note:
iTunes Store purchases or songs imported from CDs are saved in your My
Music folder by default and are not deleted by removing iTunes.
- Quit iTunes.
- From the Start menu, choose Control Panel.
- In Control Panel, open Add or Remove Programs.
- Select iTunes from the list of currently installed programs, then click Remove.
- When asked if you would like to remove iTunes, select Yes.
- After the uninstallation is complete, do not restart your computer if you are prompted to.
- If other program entries were listed for iTunes in Add or Remove Programs, remove those as well.
- In Add or Remove Programs, remove any iPod Updater applications that are listed in the same fashion as iTunes was removed.
Removing QuickTime
- Quit QuickTime Player.
- Select QuickTime from the list of currently installed programs, then click Uninstall.
- When asked if you would like to remove QuickTime, click Yes.
- If other program entries were listed for QuickTime in Add or Remove Programs, remove those as well.
Removing Apple Software Update
- Quit Apple Software Update.
- Select Apple Software Update from the list of currently installed programs, then click Uninstall.
- When asked if you would like to remove Apple Software Update, click Yes.
- If other program entries were listed for Apple Software Update in Add or Remove Programs, remove those as well.
Removing Apple Mobile Device Support
- Select Apple Mobile Device Support from the list of currently installed programs, then click Uninstall.
- When asked if you would like to remove Apple Mobile Device Support, click Yes.
Notes:
Do not manually delete the Mobile Device Support folder located at
C:Program FilesCommon FilesApple. Use Add or Remove Programs as
described in the steps above.
Removing Bonjour
- In Control Panel click "Add or Remove Programs."
- Select Bonjour from the list of currently installed programs then click Uninstall.
- When asked if you would like to remove Bonjour click Yes.
- After the uninstallation is complete do not restart your computer if you are prompted to.
Removing Apple Application Support (iTunes 9 or later)
- Select Apple Application Support from the list of currently installed programs, then click Uninstall.
- When asked if you would like to remove Apple Application Support, click Yes.
Verify iTunes and related components are completely uninstalled
- Restart your computer.
- After the computer restarts, open Local Disk (C:) located in Computer or whichever hard disk your programs are installed on.
- Open the Program Files folder.
- Right-click the iTunes folder, choose Delete, and choose Yes when asked to confirm the deletion. Note: This folder may have already been deleted if iTunes was successfully removed.
- Right-click
the iPod folder, choose Delete, and choose Yes when asked to confirm
the deletion. Click Continue if Windows needs confirmation or permission
to continue.
- Right-click the QuickTime folder (if it
exists), choose Delete, and choose Yes when asked to confirm the
deletion. Click Continue if Windows needs confirmation or permission to
continue.
- Right-click the Bonjour folder (if it exists),
choose Delete, and choose Yes when asked to confirm the deletion. Click
Continue if Windows needs confirmation or permission to continue.
- Open the Common Files folder.
- Right-click
the Apple folder (if it exists), choose Delete, and choose Yes when
asked to confirm the deletion. Click Continue if Windows needs
- Open Local Disk (C:) located in Computer or whichever hard disk your operating system is installed on.
- Open the Windows folder.
- Open the System32 folder.
- Right-click
the QuickTime file (if it exists), choose Delete, and choose Yes when
- Right-click the
QuickTimeVR file (if it exists), choose Delete, and choose Yes when
- Right-click the Recycle Bin and choose Empty Recycle Bin
Reinstalling iTunes and related components After verifying that iTunes is completely uninstalled, you should download and install the
latest version of iTunes.
Additional Information
iPodService.exe Alert Follow
these steps if the message, "Cannot delete iPodService.exe: It is being
used by another person or program" appears when you try to delete the
iPod folder.
- Make sure that iTunes and the iPod Updater utility are not open.
- Press and hold Control-Alt-Delete. Select Start Task Manager.
- Click the Processes tab.
- Locate "iPodService.exe" in the list.
- Click "iPodService.exe" and choose End Process.
- Quit the Task Manager.
Network Magic - same problem. I loaded it and printer stopped working and then 'network' headaches. I ran the magic program and it said it couldn't fix it and to order the full version for online help. What a complete crock of poop. Have unloaded it and spent hours going thru these sites looking for a silver bullet to kill Network 'junk' for good. It left traces of itself on my work laptop and my wife's laptop - i hadn't even loaded the network junk onto those laptops, but each time i boot them up, i have to manually reconnect via RJ45 - they will no longer connect wirelessly - only via hardwire hookup. I've already shut off the firewall, gone thru the registry, dll's. I have never come accross a more evil program. Having read the hundreds of posts, the folks that put this **** out should have gone out of business long ago.
I have the same..But its a pain in the arse so im trying my best to delete it.
