Microsoft Mass Effect for Xbox 360 Logo
A
Anonymous Posted on Feb 03, 2014
How to erase a mass effect character
I can go to storage and erase but when I play all the characters are still there
How can i play videos from a USB with a Kenwood DDX715WBT i tried MPEG-2, WMV, DIVX, AVI, but it doesnt play it shows Unsupported File.
These excerpts from the user's manual....
USB
Connecting a USB device
You can connect a USB mass storage class device
such as a USB memory, Digital Audio Player etc. to
the unit.
• For details about connecting USB devices, see
page 70 .
• You cannot connect a computer or portable HDD
to the USB input terminal.
• For playable file types and notes on using USB
devices, see page 75.
When a USB device is connected...
The source changes to
"USB"
and playback starts.
• All tracks in the USB device will be played
repeatedly until you change the source.
[PAGE 75]
USB playback
Playable files on a USB device
• This unit can play the following types of files
stored in a USB mass storage class device.
- JPEG/BMP/PNG/MPEG1/MPEG2/MP3/WMA/
WAV/AAC/FLAC/H.264/WMV (VC-1)
• This unit can recognize a total of 5 000 files and
250 folders (a maximum of 999 files per folder).
• Make sure all important data has been backed up
to avoid losing the data.
Notes on using a USB device:
• This unit may not play back files in a USB device
properly when using a USB extension cable.
• USB devices equipped with special functions such
as data security functions cannot be used with the
unit.
• Do not use a USB device with 2 or more partitions.
• Depending on the shape of the USB devices and
connection ports, some USB devices may not be
attached properly or the connection might be
loose.
• This unit may not recognize a memory card
inserted into the USB card reader.
• When connecting with a USB cable, use the USB
2.0 cable.
The maximum number of characters (when the characters are 1 byte):
- Folder names: 128 characters
- File names: 128 characters
• Avoid using the USB device if it might affect
driving safety.
• Do not pull out and connect the USB device
repeatedly while "Reading" is shown on the
screen.
• Electrostatic shock at connecting a USB device
may cause abnormal playback of the device. In this
case, disconnect the USB device then reset this
unit and the USB device.
• Operation and power supply may not work as
intended for some USB devices.
• Do not leave a USB device in the car, or expose to
direct sunlight or high temperatures to prevent
deformation or damage to the device
WHATS THE CHEATS OF TEKKEN 6
  • Here are some:
  • Play as Panda:At the character selection screen highlight Kuma, and press X or Circle.
  • Alternate costumes:At the character selection screen, highlight a character, and press X or Circle.
  • 2,000,000 G:Promote a character to Rouge to get 2,000,000 G. Note: This can only be done once.
  • 7,000,000 G:Promote a character to Fujin to get 7,000,000 G. Note: This can only be done once.
  • 20,000,000 G:
  • Promote a character to Tekken God to get 20,000,000 G. Note: This can only be done once.
    How can I edit an address I already have stored in my IBM Wheewriter 6 without deleting it entirely and retype it in and storing it again?
    You do not have to purchase a manual for this one job. There is a free copy at http://images.lexmark.com/publications/pdfs/2007/index/en.html
    Just go to the bottom of the page for "Typewriters" and choose your model. I believe the answer you are looking for is on page 3-25. I have looked at it myself. Here are the steps.
    Always open the storage before making a revision.
    - The store light must be on.
    Pressing Store + the number (1 to 99) always opens storage at the beginning of a job.
    If you play back too far or want to start over:
    1. Press Play to stop playback
    2. Press Store + the number (1 through 99)
    3. Press Play. (Playback starts again at the beginning of the job.)
    Use the Correction key to erase unwanted carrier returns from Stored job:
    1. Press Play or Play+Spacebar until the carrier return playb
    2. Press the correction key.
    After making a revision hold down Play while you press and release the Spacebar several times to make sure the next few characters play back correctly.
    When revising indented jobs, be sure to stop playback at the word or character you want to revise. Remember, you cannot use the Correction key to erase characters typed before you press Code+Tab or Code+Crtn. Therefore, if you play back too far, you may need to start playing back again from the beginning of the job.
    Let me know if there is anything else needed.
    Can you replace the printer ribbon on the Seiko DPU414 Printer?
    ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
    Description:
    The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
    Product Specifications
    • Model DPU-414-30B
    • Printing Method Thermal serial dot printing
    • Number of dots/line 9 x 320
    • Paper width (mm) 112
    • Printing width (mm) 89.6
    • Max Speed (character/sec) 52.5
    • Paper path Curved
    • Character matrix (H x W dots) 9 x 7
    • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
    • Number of columns 40, 80(Condensed)
    • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
    • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
    • Input buffer 28Kbytes
    • Command ESC/P * conformity
    • Cutting Tear bar
    • Operating Temperature (°C) 0 to 40
    • Humidity (%RH) 30 to 80(Non condensing)
    • Service life (line) 500,000 **
    • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
    • Mass (g) Approx.580(without Battery)
    • Compliance FCC, CE, VCCI
    Manual:
    http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
    HOW DO YOU CHANGE THE CHARACTER PITCH
    You have not specified which printer you are using.
    1. In a serial printer having a displaceable printing head and being selectively operative in a setting mode for setting a variable character pitch and in a normal mode for effecting a printing operation according to the set character pitch: a plurality of manually operable switches each having assigned thereto a normal function which is performed when the switch is operated when the printer is in the normal mode and having assigned thereto a setting function which is performed when the switch is operated when the printer is in the setting mode, at least one of the switches having a setting function which effects selective displacement of the printing head to one of a plurality of predetermined positions each corresponding to a different character pitch; means for producing character pitch data effective to specify a desired character pitch according to the selected position to which the printing head is selectively displaced; and storage means operative when the printer is in the setting mode for setting therein the desired character pitch data for use during a printing operation of the printer in the normal mode.
    2. A serial printer according to claim 1; including controlling means for controlling the serial printer to effect changeover between the normal mode and setting mode.
    3. A serial printer according to claim 2; wherein one of the switches has a setting function which enables the controlling means to set the setting mode.
    4. A serial printer according to claim 3; wherein two of the switches have setting functions which effect selective displacement of the printing head in opposite directions.
    5. A serial printer according to claim 3; wherein one of the switches has a setting function which enables the storage means to set therein the desired character pitch data.
    Storage of MS-Access 2007
    (please refer for www.office.microsoft.com for further information)
    Database specifications Attribute Maximum Access database (.accdb) file size 2 gigabytes, minus the space needed for system objects Note NOTE: Although the maximum size for a single database file is 2GB, you can work around this limitation by using a split database. A front-end database file can point to thousands of back-end database files, each of which could be as large as 2GB. For more information, see the topic, Split a database.
    Number of objects in a database 32,768 Number of modules (including forms and reports that have the HasModule property set to True) 1,000 Number of characters in an object name 64 Number of characters in a password 20 Number of characters in a user name or group name 20 Number of concurrent users 255 Table Attribute Maximum Number of characters in a table name 64 Number of characters in a field name 64 Number of fields in a table 255 Number of open tables 2048; the actual number might be smaller because of tables opened internally by Access Table size 2 gigabyte minus the space needed for the system objects Number of characters in a Text field 255 Number of characters in a Memo field 65,535 when entering data through the user interface;
    2 gigabytes of character storage when entering data programmatically Size of an OLE Object field 1 gigabyte Number of indexes in a table 32 Number of fields in an index 10 Number of characters in a validation message 255 Number of characters in a validation rule 2,048 Number of characters in a table or field description 255 Number of characters in a record (excluding Memo and OLE Object fields) when the UnicodeCompression property of the fields is set to Yes 4,000 Number of characters in a field property setting 255 Query Attribute Maximum Number of enforced relationships 32 per table, minus the number of indexes that are on the table for fields or combinations of fields that are not involved in relationships* Number of tables in a query 32* Number of joins in a query 16* Number of fields in a recordset 255 Recordset size 1 gigabyte Sort limit 255 characters in one or more fields Number of levels of nested queries 50* Number of characters in a cell in the query design grid 1,024 Number of characters for a parameter in a parameter query 255 Number of AND operators in a WHERE or HAVING clause 99* Number of characters in an SQL statement Approximately 64,000* *Maximum values might be lower if the query includes multivalued lookup fields.
    Form and report Attribute Maximum Number of characters in a label 2,048 Number of characters in a text box 65,535 Form or report width 22 in. (55.87 cm) Section height 22 in. (55.87 cm) Height of all sections plus section headers (in Design view) 200 in. (508 cm) Number of levels of nested forms or reports 7 Number of fields or expressions that you can sort or group on in a report 10 Number of headers and footers in a report 1 report header/footer;
    1 page header/footer;
    10 group headers/footers Number of printed pages in a report 65,536 Number of controls and sections that you can add over the lifetime of the form or report 754 Number of characters in an SQL statement that serves as the Recordsource or Rowsource property of a form, report, or control (both .accdb and .adp) 32,750 Macro Attribute Maximum Number of actions in a macro 999 Number of characters in a condition 255 Number of characters in a comment 255 Number of characters in an action argument 255 default.aspx?assetid=za100776681033 Top of Page
    Project specifications The following list of tables is specific to Office Access 2007 projects:
    General Attribute Maximum Number of objects in an Access project (.adp) 32,768 Number of modules (including forms and reports that have the HasModule property set to True) 1,000 Number of characters in an object name 64 Number of columns in a table 250 (Microsoft SQL Server 6.5) 1024 (Microsoft SQL Server 7.0, 2000 and 2005)
    Microsoft SQL Server database Microsoft SQL Server maximum capacity specifications are described in the SQL Server documentation. Form and report Attribute Maximum Number of characters in a label 2,048 Number of characters in a text box 65,535 Form or report width 22 in. (55.87 cm) Section height 22 in. (55.87 cm) Height of all sections plus section headers (in Design view) 200 in. (508 cm) Number of levels of nested forms or reports 7 Number of fields or expressions that you can sort or group on in a report 10 Number of headers and footers in a report 1 report header/footer;
    10 group headers/footers Number of printed pages in a report 65,536 Number of controls and sections you can add over the lifetime of the form or report 754 Number of characters in an SQL statement that serves as the Recordsource or Rowsource property of a form, report, or control (both .accdb and .adp) 32,750 Macro Attribute Maximum Number of actions in a macro 999 Number of characters in a condition 255 Number of characters in a comment 255 Number of characters in an action argument 255
    Zulfikar Ali
    1helpful
    225 mr will not play burn MP3's
    I have the manual and copied it verbatim for you. Please let me know if you need me to scan the manual for you. Acceptable medium formats: The following formats are available for the media used in this unit. The maximum number of characters used for file name including the delimiter (".") and three-character extension are indicated in parentheses. ? ISO 9660 Level 1 (12 characters) ? ISO 9660 Level 2 (31 characters) ? Joliet (64 character; Up to 32 characters are displayed) ? Romeo (128 character; Up to 64 characters are displayed) ? Long file name (200 characters; Up to 64 characters are displayed) ? Maximum number of characters for folder name: 64 (Joliet; Up to 32 characters are displayed) For a list of available characters, see the instruction manual of the writing software and the section Entering file and folder names below. The media reproducible on this unit has the following limitations: ? Maximum number of directory levels: 8 ? Maximum number of files per folder: 255 ? Maximum number of folders: 50 MP3/WMA written in the formats other than the above may not be successfully played and their file names or folder names are not properly displayed. Settings for your MP3/WMA encoder and CD writer Do the following setting when compressing audio data in MP3/WMA data with the MP3/WMA encoder. ? Transfer bit rate MP3: 8 ?320 kbps WMA: 48 ?192 kbps ? Sampling frequency MP3: 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48 kHz WMA: 32, 44.1, 48 kHz When you use your CD writer to record MP3/WMA up to the maximum disc capacity, disable additional writing. For recording on an empty disc up to the maximum capacity at once, check Disc at Once. Play mode may not be possible when portions of the functions of Windows Media Player 9 or higher are used. Entering ID3 tag: The Displayable ID3 tag is ID3 version 1.x. For the character code, refer to the List of Codes. Entering file and folder names: The code list characters are the only file names and folder names that can be entered and displayed. If you use any other character for entry, the file and folder names are not displayed correctly. They may neither be displayed correctly depending on the CD writer used. The unit recognizes and plays only those MP3/WMA which have the MP3/WMA extension (.MP3/.WMA). A file with a name entered with characters not on the code list may not play correctly. Writing files into a medium: When a medium containing MP3/WMA data is loaded, the unit checks all the data on the medium. If the medium contains a lot of folders or non-MP3/WMA files, therefore, it takes a long time until the unit starts playing MP3/WMA. In addition, it may take time for the unit to move to the next MP3/WMA file or a File Search or Folder Search may not be performed smoothly. Loading such a medium may produce loud noise to damage the speakers. ? Do no attempt to play a medium containing a non-MP3/WMA file with the MP3/WMA extension. The unit mistakes non-MP3/WMA files for MP3/WMA data as long as they have the MP3/WMA extension. ? Do not attempt to play a medium containing non MP3/WMA.
    Top Microsoft Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ELECTRICKSUSA
    ELECTRICKSUSA
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
