SOURCE: Bosch shu9905
Check the drain pump. First, manually initiate drain by pressing the second and fourth buttons on the keypad at the same time. If it pumps out, disregard the rest. If it doesn't at least hum, check for power at the motor.
Remove lower rack, lower spray arm, and screens in bottom, remove all water inside. Check for debris under pump cover in bottom of sump. The drain pump suction is through the hole on the left.
Behind the toe panel on the left is the drain motor, If no debris was found inside, the drain pump may have failed. Remove outer door panel (you may need to remove the two screws on the sides of the control panel.) Remove the metal panel across the top of the motor area , disconnect hose in front of pump, disconnect wires to pump, press tab at top of pump and rotate clockwise to remove pump. The impeller could be loose on the motor shaft, or the motor windings failed.
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
SOURCE: What is error code 2H
doesnt sound like an error code it sounds like its the delayed start feature, not sure that bosch ever used error codes
SOURCE: Very long cycle time for Bosch DW
There is a recall on the control board of many of these models, butyour problem is likely not related. I have written a guide to help. It is here. Thanks!
SOURCE: bosch dishwasher with these numbers inside door
i solved the problem by going to bosch uk website and one of the numbers came up when i went to download instruction manual
so that solved problem. thanks for your help.
