Video screen just colored dots.
May be the graphics card has fitted correctly on the slot inside try reinserting once....
or
may be this is due magnetic field appliances like speakers are very near 2 monitor so keep some distance from monitor and then on monitor press menu button and give degauss....
if still problem problem persists then may be there is some conflict with the driver so try uninstalling it and then installing it again...
or else may be there monitor problem ... just have check with connecting another monitor
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly.
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question exclamation mark ? mark ! or a red x right click select reinstall drivers if you don't have a disk with the drivers you have to download them
http://download.cnet.com/matrox-millennium-ii-agp/3000-2108_4-10028803.html
http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
