I have read several solutions telling me to lift the front of the machine and making sure the hose "clicks" into place. I just don't understand where this is--is there a way to post a picture showing exactly what I'm supposed to be seeing? The descriptives are great... I'm apparently word-challenged and a picture would help immensely... Thank you!
SOURCE: hoses to and from pump
You need to take the top part of the housing off to service this unit. There are two screws underneath / where the clear suction face is attached, and six scews on top (two up front, two near the back wheels, and two in the middle. (You have to take the water tank out to get to them). Once loose, reach up underneath the cover and hold the flow indicator while you unscrew it so it will not turn. The top will now come off easily. The hoses are pretty self explanitory once you look at the intake and outflow hoses. Starting with the pump, looking at it from the front of the machine, you have three hoses attached to it. The first one on the left is the intake hose that goes to the variable flow mechinism that the soap container sits on. It has a hose coming from the water tank inlet on one side, and the hose to the pump on the other. (The soap is "sucked" into it depending on the flow rod setting) The middle hose is attached to the suction tube on the left, and the last hose on the right is the output hose that delivers the soap/water solution first to the heater (located in up behind the on/off - temp switches), then to the flow indicater/filter, then to the two spray jets. By the way, this is not a jhob for the faint hearted... have patience. Good Luck!
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
SOURCE: I have an older model Bissell rug shampoo machine,
I have a older mod. Bissell carpet machine plus mod. 1630-5 and need a floor nozzle part num.013-6194 and grip tube w/button part num.014-4181 and trigger part num.010-9406 and tube
SOURCE: Bissell 9500 Proheat 2X won't dispense fluid.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fgjhdjk
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
