I am using a 3.3 lb. bulk propane bottle with either a 5 foot or 12 foot Accuflex high pressure hose. The small 16 oz. bottle operates the Coleman Roadtrip grill just fine, but when I try to use the bulk system, coupled with either hose, I do not get propate flowing to burners. I have noticed over the past year that the bulk system would work periodically, but now it will not work at all. The bulk bottle was recently filled, so there is plenty of propane available.
I have a new Coleman Roadtrip LXE. They will not work with a regulator on the suply tank. They work fine off a bottle or a bulk tank, again without a regulator. The regulator on the stove is not adjustable and when it is supplied with 11" wc (low pressure) it futher reduces the pressure so low the flame goes out. I attached mine to my toyhauler quick connect fitting, the gas pressure at the outside valve is regulated at the tank. This won't work, it only works if I hook the bulk tank or 16 oz bottle to the stove.
The office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
