Toys Logo
A
Anonymous Posted on Feb 03, 2014
Cannot open my secret safe by justice - Toys
Rachael Fenton
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 02, 2016
Rachael Fenton
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
18436
Points
7
Marks and Spencer My Secret Safe Instructions.
Insert the 'credit card'. If you've lost the special one with safe, any card will do, just needs to trigger the catch inside the slot.
Note: check the amount saved (Press Total Saving). The safe display will show 'error' if you try to withdraw more than is saved. If you just want to open the drawer without actually removing any money just enter '0'.
To open, press 'Withdraw' and the amount. Press 'Withdraw' again and enter your password. The safe will beep and you'll hear click as the drawer releases to open.
If you forgot passcode, there is a tiny reset button at back. Stick back of earring/pen etc and press for 10 or so secs. Then press 'Password' & default code (0000), then press 'Password' again and enter the code you want to use.
Note Deposit: Press 'Note Deposit' and amount in whole numbers - safe will jingle to say amount registered.
I can't remember how to change the date/time. Maybe someone else here can!
Maxwell SlvrHamm
Level 1:
New Friend:
  • Posted on Jan 15, 2015
Maxwell SlvrHamm
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11192
Points
7
Reference: Paisley Electronic Push Code Safe
Item # 5661462
Purchased at Justice. May be one of the following design/colors: 1. Pink and black 2. neon green 3. tye-dye (all in zebra pattern, I believe)
To gain access to safe without code proceed with the following simple instructions:
Use a screw driver to access batteries on the bottom of the safe. Remove all three AA batteries.
WAIT AT LEAST TEN SECONDS before reinserting betteries to functional position. Replace screw. Key in default passcode "0000#" Safe will now be unlocked and upon opening you can reset passcode. Hold down the "*" and when voice prompted to "key in passcode" enter new 4 digit code followed by the # sign... HOLD "*" until completed code with "#" You will hear the voice command, "enter passcode" after each digit entered. [Press & hold "*" (1234) press "#" release "*"] Close safe and new passcode should be set and work properly. If not, enter default "0000#" and try to reset once again.
Maddie Hughes
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 28, 2020
Maddie Hughes
Contributor
Level 1:
Answers
Questions
0
Helped
11192
Points
If you have an older justice safe you can open it by sticking a butter knife and playing it open
Tony Watkins
Level 1:
  • Posted on Oct 26, 2019
Tony Watkins
Contributor
Level 1:
Answers
Questions
0
Helped
11192
Points
I had the same problem but it was because even with batteries out it had enough stored power to retain the code... what works is to get a bit of metal FOIL and SHORT OUT the opposite sides off the battery compartment metal lugs
Robert Flemings
Level 1:
New Friend:
  • Posted on Feb 01, 2019
Robert Flemings
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11192
Points
We have the emoji justice locker that just keeps asking you to enter the pass code but will not except the numbers I have put new batteries in and it still just says please enter your passcode
Debbie Van Meter
Level 1:
New Friend:
  • Posted on Jun 19, 2016
Debbie Van Meter
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11192
Points
How do I open a pink zebra diary without the password I bought one second not realizing it had a digital password on it
1helpful
I can't open my bumil safe and the combinations i have are old and i think i keep getting them wrong, im not sure what to do.
Take it to a Locksmith. Most newer safes (15 years or younger) have a secret way to get inside, which the manufacturer is willing to reveal ONLY to a bonded-professional Locksmith. If there is no secret entry, then the safe will have to be drilled open (i.e. "destroyed"); and that too must be done by a locksmith because only they know _where_ to drill. Lastly, If you have electronic code entry, try installing new batteries, and retry your combination codes. Ps... I am a locksmith. I know what I'm talking about.
How to change the pin on Zebra Electric Push Code Safe from Justice.
1. Door has to be opened using previous code or the default "0000".
2. With door open hold the * button down. Both green and red lights will flash.
3. Within 15 seconds, enter your new 4 digit passcode while holding the * button. Press # when finished to store new code. Both lights will stop flashing.
4. Release the * button.
My sister locked herself out of her Justice digital safe and it is on voice mode, every time we try to reset the passcode it does not work. Does this mean that the safe is broken?
The safe would need to be open to change the passcode. Also there may be a time delay after several incorrect attempts to open. I am not at all familiar with this brand.
Bratz secret safe won't open
Hello, the lock mechanism on this gets hard to rotate after a while. You need to reset you safe by holding a toothpick on the reset button for 20 seconds. Then press the password of B R A T Z and the Angel Halo button. Then proceed to twist and pull on the safe dial until you loosen it enough to open. This can be done with your hands, you don't need a tool. Just keep working at it.
Justice password journal low batteries
I used a set of cutting pliers and lifted the back two rivets off. Then i gently peeled the paper up and slid a knife under the strap that was glued down. Replaced the batteries, put the rivets back in and used a small screw driver to mesh the strap back on the rivets. Lightly re-glued the strap and scotch taped the paper back on. Back in business, made one girl happy!
How do you reset the code on the digital safe from Justice
take out the batteries, reinsert and then use the original passcode that came with the safe. usually 0000.
Dec 26, 2013 • Toys
1helpful
How do you change a passcode on a justice digital safe
cant find any instructions online, There should be a way to by pass the code. i am gonna have to find a way to unscrew the bottom the get to items locked inside. after that the safe is useless. I will be returning it.
Feb 04, 2013 • Cell Phones
21helpful
3answers
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
