Press on/off switch and tub turns on. Shuts off after approx 10 minutes. Will not start again. 45 min later it turned on by itself. Press off and it shut off. pressed on and off a couple of times and it worked properly. let run and it turned off by itself again in a couple of minutes. Pressed on and it doesn't start again. When tub is drained the drying cycle works as correctly. Any ideas on problem.
Sounds like you may have a circuit that is bad in the control box under the tub.
Very unusual for that type of issue unless there is a problem on the circuitry.
Call a technician to have them trouble shoot it for you. It may need to be replaced. Those are not usually an item that is fixed.
Rod
US Parts Center
SOURCE: My MAAX jacuzzi runs on its own. After it is shut
Power switch appears to have a short in it. See the dealer you purchased the tub from and have them install the part.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/don_e04c7d10037aa2ce
SOURCE: I have a Jacuzzi EB30-959
It sounds like there may be a problem with the pump switch. The switch that activates the pump is based off air pressure. When you press the button to turn the pump on it sends a "puff" of air to this pressure switch which turns on the pump. This may have been damaged. Unless you bought the heater separate the heater is not there. Even still the heater is not really a heater it just maintains the water temperature.
For whatever reason the pressure switch is being activated. Don't think these tubs work right out of the box. I installed my jacuzzi tub and taking for granted that it worked I did not check to make sure the air line was hooked to the switch. Needless to say I now have an access panel in a closet in the other room beside the pump motor.
Your pump is accessible through the door opposite the drain but if it is setup like mine the switch is on the other side of the pump. Good Luck!
