It looks like the entire bottom which lines the scale and includes the battery compartment is one solid piece. I have tried a small screwdriver to pop it off but it does not work and looks like it will break parts of the side lining. Does anyone know how to get to the battery case without destroying the scale?
The whole top cover which is the part that you stand on (loading platform) comes off. Turn the scales upside down, pull the sides of the plastic cover to unclip the catches and the body can be removed from the cover. Remove the screws to the displlay and there will be a battery compartment underneath the display. Remove the cover to the battery compartment and make note of the battery orientation. Replace the battery in the correct orientation or you will destroy the scales. Repace the battery cover. Scew the display to the body. Press the cover on the body with the display showing through the window.
My Healthometer Everweigh has no battery cover. To replace the battery one must 1) Remove the cover my laying the scale upside down and pushing on opposite sides to unsnap the tabs. Do this by holding the scale over the edge of a counter and pushing down.
2) Unscrew the two Phillips screws holding the LCD display.
3) Once the display is loose, turn the display over to expose the battery cover.
4) Unscrew three Phillips screws holding the battery cover.
5) Remove the battery (2032)
