Will not respond to any buttons and turns itself off I've only music files onboard and have even deleted some albums but same message
SOURCE: Samsung YP-Y7JX
Have you tried deleting this 4MB ? ... try it.. if it didn't work.. then hard-reset your MP3 Player, because there is an error in your DB structure caused by false-copying or power spike... something like that.
SOURCE: no space for db error message
I have the same issue on my Samsung YP-T7JZ player. Nowhere has a solution. Search on web for days, nothing found. Only solution is, throw it against the wall. Collect the pieces and send them back to the manufacturer because these tech supporters don't know what this issue is.
SOURCE: samsung yp-u3j ZB/XEU freezing/computer not recongising after i deleted files from the device
Hi...I find the answer...Push and hold rec button and button for holding...And it will start..
SOURCE: 'please delete more than 60 MB" samsung yp-p2
An option that you can do is to transfer your files to your computer then format the drive. it is possible that there are errors on the drive. After that just put the files back in and check if its okay already
SOURCE: ' Please delete more than 60 MB' samsung yp-p2
all smiles now... the experts advise was excellent
