How do i change my craftsman 919165200 air compressor from 120v to 240v?
Your Craftsman model 919.165200, 5hp, 20 gallon compressor was designed to run on 115~120v 15amp. I believe that it was made by Campbell Hausfeld and is of the oilless single cylinder type. If however your compressor is oil lubed and has a motor /drive belt configuration it may be able to convert if there is a spec plate on the motor with alternate wiring diagram. Many high-end compressors like Rol Air, Jenny, Dewalt, etc with motor/belt drive have a switch selectable voltage, however one must still change the power cord when using 220v. Good luck with your projects and post again if your have other question.
