Freezers Logo
A
Anonymous Posted on Feb 02, 2014
MQU1556AEW maytag freezer ices defroster coil up and fan doesn't run
5 Related Answers
Anonymous
  • 828 Answers
  • Posted on May 16, 2008
SOURCE: MAYTAG,AUTO DEFROST PROBLEM
The defrost timer is normally located in the area of the temperature controls. There is a clutch head knob on the timer which can be rotated clockwise very slowly until a click is heard. Wait 30 minutes and defrost should take place in that time period. If defrost does occur and the system does not restart cooling, rotate the knob more and you will hear a second click and the compressor should start .
If the system restarts in the cooling mode in 18-22 minutes the defrost timer is good and the problem is more than likely in the defrost heater circuit.
docjohn174
john gagnon
  • 943 Answers
  • Posted on Sep 27, 2008
SOURCE: Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Anonymous
  • Posted on Apr 07, 2009
SOURCE: maytag upright freezer model MQU1556AEW
I experienced the same problem last week with my freezer. Apparently the change in temperature during defrosting allows the blade locking mechanism to slide on the motor shaft during the spinning operation. The blade pulls itself along the shaft until it comes in contact with the motor mounting bolt. If your freezer just stops getting super cold, but remains cool and you don't hear the fan spinning, remove the inside back panel and check the fan blades for freedom of movement. I almost disposed of the freezer this past week but decided to make one last check of the mechanisms.
Anonymous
  • Posted on Apr 08, 2009
SOURCE: Maytag model MQU1556AEW, frost-free freezer forms ice in bottom.
I'm not sure if this will help but the freezer that is located on the bottom of my refrigerator started forming ice on the back part where the cold air was supposed to be coming out. I kept hearing a hissing sound like water dripping on a hot surface. I called the repair man in and he had to replace the defrost timer. Once he did that it worked like a charm.
I am not an expert by any means although removing ice from a frost-free freezer is a pain and this took care of the problem for me. Good luck!
Anonymous
  • Posted on Feb 15, 2010
SOURCE: Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
I purchased this Frigidaire freezer three years ago. Around a week ago, I noticed that the items I had stored in the freezer have begun to thaw slowly. Although the freezer is still "working", it...
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for icw build up. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check evaporator fan in freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
Hi I have this maytag upright freezer model # is MQU1556AEW the problem is that at the bottom inside the freezer there is alot of ice i dont know where this water is coming from I clean but that ice every...
We too have this 2005 model and have to remove ice at the bottom each month....solution...buy a new freezer before we lose all contents.Looking at Amana...high ratings and few complaints
I don't have an owners manual and want to know where I should set the freezer to avoid unnecessary ice build-up. Also is there a setting for defrost?
Click Here for your user manual=> MQU1556AEW.pdf The settings for defrost should come automatically every 12 hours. You may test the defrost timer that appears to be behind the kick plate at base and front bottom of refrigerator by removing the kick plate first and using a flathead screwdriver turn slowly clockwise until compressor stops. After a few minutes you should be able to hear a crackling noise or sizzle by opening the door and listening. Leave the timer like that for up to 35 minutes and if the freezer does not start on its own the the timer is not working properly and will need replaced. Click Here=> MQU1556AEW Unit parts number 15 in photo is defrost timer. The defrost timer is part number=> 4357124 Defrost Timer Check for air leaks around door seal as this will cause the same symptoms. If by chance the defrost timer works and the defrost does not then let me know here or here=> Appliance 911 The only other parts are the defrost heater number 16 in photo MQU1556AEW Unit Parts and part number for defrost heater is Click Here=> 8201749 If you change the defrost heater it is always good to replace the defrost thermostat number 18 in MQU1556AEW Unit Parts The defrost thermostat is part number=> 1-81801-001 The most likely problem is the defrost timer but I needed to cover every possibility. If you have questions please feel free to ask, Thanks, Sea Breeze
10helpful
4answers
any help ?
I have a maytag freezer does it self defrost?
If it has a fan in it, it's self defrosting. The moving air burns away the frost and 8 out of every 24 hours, the defrost timer will turn a heating element in the cooling coils, to melt away any ice buildup.
If it isn't a self defrost model, you can safely defrost it woth a pan of hot water. I also use a spray bottle woth hot water to help the process. DON'T use anything electrical to make the heat. Water can drip into or onto it and you could get electrocuted.
1helpful
MAYTAG MODEL# MQU1556AEW, HAS POWER, LIGHT COMES ON, QUIT COOLING, WE LIVE IN THE HILLS, NO APPLIACE REPAIR PEOPLE, HAVE ELECT TESTER AND BASIC KNOWLEDGE, I COULD USE DIAGNOSTIC MANUAL OR HELP,, THANKS
If the fan in the freezer is working , but the compressor is not , then the overload/relay is bad ( pt # 4356738 ) . If you hear nothing , then the defrost timer is bad ( pt # 4357124 ) . This part looks like its located close to the compressor or in one of the corners of fridge on back with about 1/2 " hole to access manual turning slot . Turn the slot and see if fridge starts .
2answers
Maytag Freezer mqu1556aew 2004-07.Ice buiding up on the bottom of freezer.
if self defrosting model check frozen drain in freezer
Aug 09, 2009 • Freezers
2helpful
8helpful
4answers
Maytag upright freezer model MQU1556AEW
Sep 22, 2008 • Freezers
Top Maytag Freezers Experts
john h
ADMIN Andrew
ADMIN Andrew
vince
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
