SOURCE: maytag upright freezer model MQU1556AEW
I experienced the same problem last week with my freezer. Apparently the change in temperature during defrosting allows the blade locking mechanism to slide on the motor shaft during the spinning operation. The blade pulls itself along the shaft until it comes in contact with the motor mounting bolt. If your freezer just stops getting super cold, but remains cool and you don't hear the fan spinning, remove the inside back panel and check the fan blades for freedom of movement. I almost disposed of the freezer this past week but decided to make one last check of the mechanisms.
SOURCE: Maytag model MQU1556AEW, frost-free freezer forms ice in bottom.
I'm not sure if this will help but the freezer that is located on the bottom of my refrigerator started forming ice on the back part where the cold air was supposed to be coming out. I kept hearing a hissing sound like water dripping on a hot surface. I called the repair man in and he had to replace the defrost timer. Once he did that it worked like a charm.
I am not an expert by any means although removing ice from a frost-free freezer is a pain and this took care of the problem for me. Good luck!
SOURCE: Maytag Freezer mqu1556aew 2004-07.Ice buiding up
if self defrosting model check frozen drain in freezer
SOURCE: my upright freezer compressor is running but the
The problem is the evap. fan has gone bad. Part # WR60X10235, cost approx. $120.00 or the TJ90sm999 is one that will fit all of them which is only $25.00 and in my opinion a much better fan. Hope this helps. The sm999 has been around for years and is a universal fan which is easily adapted to fit all 115 volt evap fans like yours.
SOURCE: Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
